Old 07-27-2006, 08:15 PM
demonsvx's Avatar
demonsvx demonsvx is offline
building more AK47's
Rear transmission seals SVX to Outback
Are the rear seals(driveshaft) different between the SVX 4eat and a 1996 Legacy Outback 2.5 4eat? I noticed mine to be leaking more than it should dripping all over exhaust smoking like crazy. Any responses are well appreciated thanks Damian
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT
Old 07-28-2006, 12:04 AM
Speedklix's Avatar
Locker Link Solution
-did you clean them first?
if yes, did you also grease them?
-did you notice a little spring acting like a rubberband inside?
are you sure it is the seals and not the side plates?
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 07-29-2006, 12:33 AM
AvPPoW AvPPoW is offline
If you're reffering to the extension oilseal, they're the same, but the one that came on the transmission might be damaged. The subaru part # is 806735200 and they run anywhere from $10-15 from dealers.
Cheers
Old 07-29-2006, 03:21 PM
demonsvx's Avatar
I looked the parts up at Autozone and if i remember they had different p/n for the seals. Oh well I guess Im changing them out regardless.Thanks for the help
