TC Bolts won't come off.
I've used all of my tricks. PB blaster, patience, tapping them with a hammer gently, whispering sweet nothings to them...
Then, I lost patience, said screw it and stripped one with a vice-grip. Crud. Any suggestions?? Can I take the tranny off with out removing those bolts? Thanks |
Breaker bar? I find one of those to be immensely useful on really tight nuts.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
use a small die grinder and go at it. I had one hang up on me and it took me 20 minutes with a die grinder and it came right out. Just be careful you do not dig into the flexplate and be sure you buy new bolts
TOm |
So I can just grind the heads off of the bolts that don't come off? I'll be carefull with the flexplate. Thanks alot, Noah |
Agreed with Subster, it's a matter of gripping the bolts.
And young Tom's solution may be your only choice. Bolts must be removed. Svxfiles likes to remove the alternator, and go in with a six point socket and several long extentions. I don't believe this has ever failed him. I've done it both ways, with luck so far. If you are careful, you may get enough bite on the bolt using svxfiles method, even after the vise-grip mess. Good luck, let us know what happened. Quote:
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 Last edited by NeedForSpeed; 07-22-2006 at 01:46 PM. |
Thanks for the advice. Do you know what size they are? I'm at work now. I bet they are standard, not metric.
I'm willing to take the alternator off. I didn't realize it was an option. Quote:
In reply to the problem your having with torque convertor bolts. Just changed my transmission I had one bolt that did not want to come out. Got under the car with an air chizle with a pointed bit. Got on the edge of the flange and rotated the bolt out. Be sure to put in new bolts with locktite. Fishtail
I hope it goes better for you.
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT |
if you remove the TB you can just use a 12mm 6point sockt on a ratchet...no extensions needed... this proves to be the best way to do it as there is no need to buy extensions and less chance you will round one off as there is less torque applied to remove it... Just an opinion
Tom |
Sears 12mm racheting box end wrench .... don't even need to take the TB off...
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$ |
I held the prybar in one hand to steady the crank and just a ratchet and 12mm to break the bolt free standing on the pass side. I then used a 3 inch extension (with no ratchet) to turn the bolt quickly and remove it. turn the crank to next bolt and repeat. If I knew I didn't need that flexplate again, I'd probably just take a wizz wheel underneath and cut off the heads where you would install the stopper. The die grinder is a good idea, though if you have the patience and want to keep the flexplate.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
Wow, great response! Thanks for all the advice. I'll be back at it on Monday. I have the throttle body off already so that's helpful in terms of access to the bolts. I'll let you all know how it went.
I didn't realize how many people have done the swap! That's cool. |
Or had to re-do it Tom |
Thread Tools | |
Display Modes | |
