best crank pulley options?
Where can get a get a crank pulley for cheap assuming that I need one? Dayle sells his for 140....and the one from subaru parts is about 148...anyone?
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
Get Dayle's as it will be the last one you'll ever need.
If you get OEM size you won't need belts.
Is dayle's OEM size?
He has both OEM size and underdrive size.
on a bit of a side note...
i bought dayles oem size... installed it without a hitch, and recently noticed its wobbling... in fear of it being loose i tried tightening it as much as i could... however it didnt turn at all... how would the aluminum one wobble? seems to get smoother when i yank on the throttle cable a bit... could the bolt have bent some how? or even the pulley? doesnt make sense, but i cant worry 'bout it too much...
'96 Saab 900 turbo '95 Passat (drove the wheels off) '92 SVX Ls-L (smashed/sold) '88 Acura Legend (wheel fell off) '90 Audi 80 quattro (50mph into side of truck) '95 Saab 9000cse turbo (sold) |
perhaps your crank bolt is cross-threaded?
ook! that sounds bad..? as long as i'm not trashing belts or busting timing belt covers, i'd be okay though? right?? actually my timing belt cover already has a hole in it, from my first pulley that went crap..
'96 Saab 900 turbo '95 Passat (drove the wheels off) '92 SVX Ls-L (smashed/sold) '88 Acura Legend (wheel fell off) '90 Audi 80 quattro (50mph into side of truck) '95 Saab 9000cse turbo (sold) Last edited by 92SVXLS-LDC; 07-14-2006 at 01:31 PM. |
I have the aluminum underdrive and it wobbles ever so slightly too. I wouldn't worry too much for as long as it's not contacting anything or hurting belts.
My underdrive pulley has recently started wobbling for no apparent reason.
You guys are freaking me out. I'm going to go check mine after work! (or maybe even during lunch)
So i guess i'll be going OEM size
n00b on demand, mines oem size(aluminum) and i'm the one that started the wobbling pulley thing, at least in this thread...
maybe its just an aluminum thing, regardless of size?
ohhh ok i gotcha. Thats still weird that alot of you have a wobbling issue.
i can guarantee the wobbling was worse before i got the aluminum pulley though, it shredded 2 belts in a day, and right through my t. belt cover...
I have the OEM-sized one-piece pulley and can't imagine how the part itself could fail, when properly installed. But I suppose stranger things have happened.
dcb |
Thread Tools | |
Display Modes | |
