Old 09-08-2005, 09:27 AM
1992SVX 1992SVX is offline
valve cover gasket
well yesterday i got one of my oil leaks fixed. i got the valve cover gaskets from subaruparts.com. can i say what a PITA. the passenger side took about an hour to do. and the driver side took 3 hours to do. i could not even get driver side one out of the engine bay. so i cleaned as much as i could and dropped in the gasket and it turned out fine.
p.s. it was not as bad as i thought it would be
1992 pearl svx (given away)
Custom Cold Air Intake
Stage1 Shift Kit
Brembo Cross-Drilled/ Slotted Rotors. Front and Rear
4.44 gears
now in better hands of svxfiles
Old 11-11-2005, 01:52 PM
OK I HAVE A QUESTION and I didn't want to make a new thread.
Do I have to drain the oil to open up the valve covers?
I mean is there not oil that's going to spill out if I open them up or should I drain a quart or two first?
Old 11-11-2005, 01:58 PM
No Nik, You don't have to drain the oil to change the valve covers....there might be a little pooled up to runout, but not much...the oil drains to the oil pan, which is lower than the valve covewrs..hope this helps..
Old 11-11-2005, 02:02 PM
Yes it does and now I just have to wait for things to cool down. :DDDD
edit: Uh but Eggo says I should do it now wtf?
Old 11-11-2005, 03:07 PM
Don't you ever take out a pan or a cover from the engine unless it is cooled 100%. Believe me i have seen engine get F***ed up because of that
The thing is the seperated parts get wavy surfaces when they are still hot.
Old 11-11-2005, 03:35 PM
Rotorflyr's Avatar
edit:but Eggo says I should do it now
Mmmmmm Eggo's..........
2006 B9 Tribeca
Old 11-11-2005, 03:59 PM
AHA! That was great.
Been about 2 hours sitting there. I wonder if it's ready for teh me.
Oh wait no, 3 hours. Should be good.
Old 11-11-2005, 04:29 PM
So which side is considered left? Intake side? Battery? I'm assuming the passenger's side...
Old 11-11-2005, 04:31 PM
Generally from the drivers position facing forward.
And yeah, the left has a lot more crap in the way of getting it out.
Old 11-11-2005, 09:30 PM
The inside of the covers are marked pretty clearly.
I'll get photos up sometime tomorrow.
