water in trunk!
well, i got in my trunk yesterday and opened up where my spare is and there was a bunch of water laying around on the floor. it wasn't a huge amount,but i've never seen water in there before so wtf?! any ideas on how to figure out where it's coming from?
Should be another easy one. Do you have tail light condensation? If so take out the tail lights and seal the gasket "both sides to be safe" with some regular RTV, clear or black. This should take care of both problems. If you still have a leak you might want to seal the large plastic plug below the tail lights, Ive seen thatr leak to.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
Also check the power antenna drain and sunroof drain pipes
i do have taillight condensation so i'll check that out tommorrow. i'll check those drains too. thanks guys!
Some Svxer's used to have that problem with water in the trunk. So you're not the only one
Wash your car and see what happens. I'm guessing tail light seals. |
I remember someone else posted they had water in the trunk due to the seal leaking around the main deck lid maybe you can do a serach good luck!
Double thanks, found water in my car's lower trunk area. No tail light condensation though. Trunk seal looks fine, upper area dry, will check those antenne and sunroof drains.
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
I wouldn't put silicone on both sides of the gasket as you'll never ever get them off the car again.
Well,
I thought I was the only one.... Um I get water in my trunk, and my left rear tailight gets condensation... Whats the easiest way to fix both?? silicone? Last edited by crimsonnblue; 09-06-2005 at 04:54 PM. |
mine is the same way too. i get very little condensation in the right light but plenty in the left. i've had that problem since i got it but never had water in the trunk till now though. didn't have time to look at it today but i will tomorrow. |
I recentlyjust got this car and Well I noticed the condensation. What is the best thing to use to seal the tailight. And trunck.
Do I need to pull out the taillight assembly. What exactly is making water leak into the trunk? |
I put silicone between the taillight and gasket then grease between the gasket and body to stop the condensation in the taillight and water in trunk.
Sweet Thanx |
Water in my trunk?
I Just noticed water in my trunk. I think it may be from the main seal. It rained here really hard. I don't think it was coming from the tail light area, because the rear carpet and masonite board were wet on the left side. Anyone seen this before? This car doesn't have a sunroof, so i know it's not that.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) Last edited by NiftySVX; 08-24-2007 at 06:36 PM. |
I had a similar thing happen to me. when i bought the car there would be condensation in it every morning! there would also be a puddle of water in the trunk. the culprit was the pas. side tail light, it would leak behind the seal so i siliconed all the rear lights and no more water yours sounds light it might be the seal that goes around the trunk or the rear panel light on the trunk. try sealing the gasket and it might work.
