Old 09-03-2005, 12:08 AM
chitownsvx chitownsvx is offline
my car is missing during takeoff
My car is missing and it hesitates during acceleration and the check engine light is starting to come on. Could this be a simple tune up.
Old 09-03-2005, 07:12 AM
immortal_suby's Avatar
Thread Killah
Check the how to lockers for how to pull up the check engine diagnostic codes. Could be simple, could be expensive, could just be bad gas. . Hard to tell until you check the code.
Locker Link
2015 BRZ Limited 6MT
Old 09-03-2005, 09:18 PM
svxwannabee
my '96 legacy gt did that and it was a loose spark plug wire, long shot, but it'd be easier than something else that could go wrong
Old 09-04-2005, 07:28 PM
wawazat??'s Avatar
Yeah, I'm still around
With the coil on plug system the SVX uses, this is not likely. Coil could be failing however.
Could also be:
-tune-up (bad plugs, air filter)
-MAF failing
-fuel filter clogged
May also be other sensors failing.
Start with the easy-n-cheap stuff and work up.
Todd
Down to none
