Old 08-29-2005, 04:24 PM
The Molinator
ECU tune Stage 1
Please let me know if the Stage 1 chip Motersport Warehouse sent me will change my SVX to 87 octane usage? I can't get my PC to connect with ECUtune for this info...???
THANKS!
Jim
Old 08-29-2005, 04:33 PM
It will support both 87 and 91 provided you wire in a switch to alternate between the 2.
Old 08-29-2005, 07:33 PM
The Molinator
87....or ...91 ...octane
Please give me any info you have about whether this is a good mod....in other words..Is there any negative consequences to me adding that switch and using 87 octane? [I've never complained about Premium prices until recently!!!....HA!
THANKS!....again!
Jim
Old 08-29-2005, 07:53 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
THANKS!....again!
Jim,
You should be fine. LAN's chip alters the ECU map to allow you to use 87 without running into spark knock.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
