92 wiring diagrams
does any one have the wiring diagrams for our cars?....Im looking to do some mods but dont have enough info on the wiring
What do you need to know? Several of us have FSM's.
mostly intersted in the dash electrical
Can you be a little more specific
do you mean the cluster? anything in particular ur trying to do
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
Here's are basic diagrams for the SVX cluster. Pin identification is by connector/row/number ...not color. Let me know if u need STi info too.
That helps alot. Yeah I might need the STi gauge cluster info also. Seems you know much about wiring. If you look at both do you think its possible?
Unfortunately it's more than just connecting wires. If you want to swap the STi gauges in it might be calibrated differently - most likely it is and the readings will be off.
Autometer gauges will work. Just a heads up ...doesn't hurt to try though. If you're handy with electronics you can calibrate the new gauges electrically. Pulling the needles off and moving them might work - might not ...odds are it won't work for the full range.
Thats what I thought. Ill just have to do with the AutoMeter stuff, and try to use the WRX cluster bezel that has 2 pods on it for gauges.
What about the diagram for the clusters of the security/cruise/fog switches? My light went out on the buttons and I usally dont use those three anyway.
