2001 4EAT question...
I've got the chance to pick up a parts Forester for cheap.
It's a 2.5 with a 4EAT in it, the motor is most likely fubarred, as the right timing sprocket is shattered, but the tranny and rear diff are fine... So I'm asking it a 2001 4EAT will work in a SVX, or other earlier Legacy/Impreza car. I know they are a little different, as it has the screw on filter on it, but I doubt Subaru would have really changed anything major on it, and I'm figureing it would most likey be a plug and play set up... Just wondering if anybody has installed one. I need to know by next week, if I want to get it.
I hope someone has an answer. I was hoping a newer replacement would work when the time comes.
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
I think there was a dicussion on this a while ago, and it was decided that the newer 4eats would not work because of a different gear brake mechanism (no longer using bands) on the newer 4eats. Harvey and Porter were discussing it. Maybe you can find the thread. I think it was the thread where Porter was thinking about using a JDM 4eat.
Correct Mychailo. Oab also was talking about this recently in a thread in the mod section.
http://www.subaru-svx.net/forum/showthread.php?t=27966 Huck, the newer trans could be made to work, however, the TCU and wiring to the trans would need to be changed as well. The newer VTD 4EAT's use a clutch system instead of a brake band system. -Chike
From what I understand, all the Subarus with a 4EAT trans in the '99 or later model year had a VTD (variable torque distn) system that gave the car a torque split of 45/55. -Chike
Not impossible, but you would need a good Auto Electrican, to do the wiring. Harvey.
Thanks Harvey and Chike...
So it wouldn't really be worth gettin, unless i had someone that wanted a 2001 tranny....oh well....didn't really have the extra money anyway....
VTD is only found in the WRX, Legact 2.5GT, OUtback 3.0 VDC, and Baja Turbo. Dave |
Dave, So are you saying the 2001 Forester Tranny WILL work in a SVX?
I couldn't say for sure. But I can tell you that the Forester does not have VTD. Dave |
There are 17 wires that run between the TCU and the gearbox, 14/15 on the SVX. The plug on the later TCU are 3X24 pin plugs, different to the SVXs 3 plugs of 1X12 pin, 1X16, and 1X20 pin, so the SVX wiring would have to be fitted to the later TCU plug. It also uses an extra speed sensor on the torque converter turbine, to sense the engine load. I have not sighted the plugs on the later TCU, but they are different to the SVX plugs. It may be possible to pull the wires out of the later plug, and fit the SVX wires into it, along with some new ones. You would also need the section of the loom that runs down to the gearbox along with the plug for the gearbox. Looks like a job for Huck, to be the first to graft a later auto. Harvey.
Well if I got it, I would have the whole vehicle (or at least what’s left of it ) so I would have all the wiring and TCU at my disposal… but as my current cash flow is really low, I hate to drop money into it when I don’t even have anything to use it in currently…I wouldn’t mind having the engine around for parts…but there really isn’t anything on it I need, the good parts are both pass doors, and the tranny and rear diff, and the front seats, and a set of Forester steel rims….pretty much everything else is smashed or already gone….so I guess I’m going to have to pass on it….
Thread Tools | |
Display Modes | |
