Old 08-21-2005, 03:25 PM
SubaSteevo's Avatar
No longer blue member
Do you have full coverage?
Have a friend blow it up, then use the money to buy a Civic. Hopefully you'll get one that's RWD
-Steve
01' MSM Lexus IS300
Old 08-21-2005, 09:08 PM
92AWDSVX
no Liability
Old 08-26-2005, 01:27 PM
Nobody Nobody is offline
Send a message via ICQ to Nobody Send a message via MSN to Nobody
Hi there, so car has been checked and it is little bit complicated.
It is for sure that part of the problem is right CV joint (will replace both sides). The other part of the problem is that it seems there is bad central bearing on prop. shaft or whole connection of both prop. shaft parts, maybe even bearing at the rear diff side. Too much things to check, keep posting results.
Petr
Petr
"It is never bad enough, it could always be worse"
Old 08-28-2005, 09:48 AM
Umm. Get new front shafts and plan on buying a new diff.... When you plug the fuse in, it makes it FWD not RWD. Also, please remember this is a family site so no profanities, just relax, freaking out on the people here will not do anything but get you more angry when the replies stop.
Old 08-28-2005, 11:01 AM
immortal_suby's Avatar
Thread Killah
Too true, Tom.
I tend to not reply or not even read posts with vague titles (please help!) instead of descriptive titles and when the ALL CAPS and bold letters start rolling in.
92awdsvx - your picture has been removed since you ignored Todd's request to remove the profanity.
Locker Link
2015 BRZ Limited 6MT
