Old 08-13-2005, 07:47 PM
92AWDSVX
Somebody PLEASE PLEASE PLEASE help me i am desperate!
Im driving my car its going fine then out of no where i make a left turn to go to my friends house, and i hear this loud ass BAM! I thought something fell off my car. Look behind me nothing....
Everytime i make a turn at normal speeds it will BAM BAM BAM until i streighten the wheel. and at slower speeds with my door open i can hear like the wheel not rubbing right on the assphalt (spelling) u can hear that noise.. and sounds like **** is breaking off the car!?!!
PLEASE HELP WHAT COULD IT BE!!
92AWDSVX
I Am Desperate Please Help Me!!
PLEASE HELP WHAT COULD IT BE!! I AM DESPERATE
Old 08-13-2005, 07:51 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Sounds like you killed a front axle.
Old 08-13-2005, 07:52 PM
92AWDSVX
I can almsot guarentee the noise is coming from the rear... not 100% but i was listening and it sure sounds like its coming from the back and the rear wheel is the one that is rubbing
Old 08-13-2005, 07:55 PM
benebob's Avatar
Strut broke out of the mount then most likely but could still be an axle.
Old 08-13-2005, 08:03 PM
92AWDSVX
it happens when i dont turn also though, and its LOUDER THEN HELL ITS LIKE A LOAD BAM!!! sometimes even when i go streight i will hear the BAM and i mean its loud like it scares the heck out of you
DO YOU HAVE AIM ID LIKE TO TALK TO YOU ON AIM, I NEED TO GET TO WORK, AND THIS IS THE ONLY CAR I HAVE...
Old 08-13-2005, 08:11 PM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
Translation: A constant Velocity, or CV joint on the front half-axle is worn out and about to fail.
I agree, the symptoms sound exactly like a CV joint preparing to die. The noise probably sounds like a loud "clicking" or clattering coming from one of the front wheels when you turn a sharp corner. As it gets closer to failing you will notice that it happens even when you turn the steering wheel only slightly. When it gets really close to death, the steering wheel will buck and jump. When it makes noise or causes the steering wheel to jump while driving in a straight line, the failure is imminent.
CV noises don't always sound like they're coming from the front. Either hang your head out the window or have somebody nearby listen as you drive around slowly. It's possible that it may be something else, but a constant clicking while turning is a classic symptom. ...if that's what you're experiencing.
Crawl under the car and look for the rubber boots with bellows on each half axle. There will be one next to the wheel and one next to the transmission for each half axle. One of the outside ones nearest the wheel has probably failed. There will probably be a bit of grease spattered around that area. The only cure is to replace the CV shaft. It will eventually fail, and it might damage your transfer clutch if you try to continue driving when it does fail. Inspect the CV boots carefully for a tear. If you don't find any damage to a boot, then your CV joints are almost certainly just fine.
As long as the clicking noise only happens when turning corners, you've got time. Once it starts happening while driving straight, it will fail very quickly. Sometimes you can drive for years if it only clicks while turning, but you're lucky if you get 50 miles if it starts to misbehave when driving straight ahead.
UberLocker
Old 08-13-2005, 08:18 PM
92AWDSVX
it isnt a click, its a BAM a LOUD BAM. sounds like 2 trains colliding. and the wheel will wobble and rub on the sidewall a little it looks like...
Old 08-13-2005, 09:43 PM
mbtoloczko's Avatar
sans SVX
My guess is front differential or CV joint. I guess you need to get a look underneath the car.
Mychailo
Visit my locker
Old 08-13-2005, 09:48 PM
Try doing a figure 8 with it in a big parking lot. See if it responds the same in each direction.
Old 08-13-2005, 10:16 PM
92AWDSVX
[IMG]deleted - remove profanity if you want it back up[/IMG]
Those circled thing look messed up to me, they are differant then the other side. i dont know what they are That is a pic of the passenger wheel
Then this is a pic of the "good" looking side (driver)
Also, i need new rotors, i dont know if that will matter or not..
Old 08-13-2005, 10:22 PM
92AWDSVX
it also feels like its grabing on the left turns and wanting to go the other way.
The noise seems to be coming from the rear driver wheel.
REPOST PICTURE WITHOUT PROFANITY! Don't do that again! - wawazat??
theres a pic of the parts that look messed up, thats a pic of the PASSANGER SIDE
I need new rotors i dont know if that will matter or not
Old 08-13-2005, 10:36 PM
svxwannabee
This is a long shot and probably not it, but make sure all your lugnuts are tightened on all your wheels. Not something people generally think of when things go wrong. And let's just say I know to check this from experience (pissed off the wrong people in high school). Hope you figure out what's wrong.
Jeremy
Old 08-13-2005, 11:59 PM
UberRoo's Avatar
SVX Appeal
Well, in that case...
Yes, the lug nuts are a good bet. It sounds like you need to jack up the car and start wiggling parts until you find something loose. The part you circled on the right is part of the anti-sway bar. It's not very important and unlikely to make much noise. The part you circled on the left is quite a bit more important, but as long as it's not broken, but only bent, the only consequence will be an alignment problem which isn't a big deal and it also does not explain the loud noises.
Your descriptions, "bent," "f----d," and "grabbing on the left turns," are too short to be useful. What grabs? How can you tell? What does it do when it grabs? What's bent? The rod? The joint? The bolt? How is it f----d? Is it loose? Is the metal bent? Is the rubber boot broken? I don't mean to be obtuse, but what kind of BAM are we talking about? "Bam" isn't exactly the word I'd use to describe two trains colliding. Bam is useful, but would a dull thud be more accurate? Does it sound like somebody kicking the wheel, or more beating on it with something harder like a bowling ball? Does it sound like somebody beating on something other than the wheel? Beating on what? With what? How hard? Sorry to be difficult, but I can't tell you what was wrong with the Titanic from a ticket stub, nor can I tell you what’s wrong with a car simply by knowing it makes a noise.
We need specifics. Every clue counts.
There's not much else I can suggest other than getting the weight off the suspect wheel and finding the loose part, as that sounds like the problem. [pun intended]
UberLocker
Old 08-14-2005, 11:00 AM
mbtoloczko's Avatar
sans SVX
That's the rear suspension, so is the sound coming from the rear of the car?
Mychailo
Visit my locker
