Old 08-11-2005, 09:21 PM
well good luck with the xhaust. The ABS sensors are not hard to get to, they are on the other side of the rotors It is not uncommon to get front wheel spin with the svx just for a moment though and then the rear wheels should swallow up that wasted power
Old 08-11-2005, 09:24 PM
pnyklr
Thanks... I wish I could figure out which sensor was bad ... I wodner how I coudl do that ... he suggested the dealer I would like to avoid that
Old 08-13-2005, 10:38 AM
Originally Posted by Capuano
I haven't noticed it running hot so much (about mid dial) as I have noticed that it seems to STAY hot under the hood for a long time after the car is off. last night I went under the hood two hours after pulling into the garage, and the alternator, compressor, and of course the engine were still quite hot. I put a tie cable on the muffler shield, and the muffler had cooled off by then.
As far as the tranny goes, the previous owner had his go out at 120,000 miles. It wasn't heat that did his in, it was the in-line screen that had plugged up, and prevented fluid from flowing anymore.
-That sounds about right concerning the lack of space around the engine. The heat has nowhere to go.
-If the screen/filter was clogged and fluid/coolant wasn't flowing, heat was the COD.
Old 08-14-2005, 08:30 AM
Know someone with a lift and a MIG welder? That's how I fixed mine I was lucky I shopped around for a Lube place that had a MIG welder as the guy was draining the oil I said would you mind hiting the heat shields with a few spot welds I think it is ratteling. He did I gave him $5.00. a little more than a $1.50 Hose clamp.
Old 08-14-2005, 10:10 AM
pnyklr
I bought the exhaust and front pre-cats from motorsports I just have to get it all on the car
Old 08-15-2005, 03:16 PM
crimsonnblue
so, does the hose clamp just fit around the two shields? I got under there and began to feel around. I didnt feel anything loose, but the pipe right after the converter rattles when I tap on it. The shields werent loose when I touch them and that makes me think its comming from inside of it.
So should I just slap the hose clamp around the two shields...
Old 08-15-2005, 08:26 PM
You positive that's not the cat rattling?
Old 08-15-2005, 08:35 PM
Noir's Avatar
Noir Noir is offline
Originally Posted by TomsSVX
HAHAHAHAHAHAHA... you make me laugh.
With all the mods/maint I put into my SVX in less than 1 year probobly amount to 10k alone!!! not to mention starting price
Tom($$ spending member)
tommy stop giving the kid such a hard time. maybe his financials can't support the ownership of the svx.
on another note, i spent $6k for my svx and i think i have well over $6k in upgrades and maintenance. i'm such a sucker for my svx.
all within a year.
Old 08-15-2005, 09:21 PM
I was breakin Chike's marbles not his. If you can afford to have a GN for a toy, I am sure you can afford to keep an SVX running in "decent" shape
Old 08-15-2005, 09:32 PM
pnyklr
I can afford to have the GN as a toy but I cant afford to have a SVX thats a POS that was the issue
I doubt an 18 year old SVX (if it existed) would fetch the same as a GN and the GN was a $20,000 car fully loaded taxes included and I believe the SVX was a $30,000 + car
An 87 GN can easily fetch $10,000 even with some mileage
Old 08-15-2005, 09:33 PM
Originally Posted by pnyklr
GN's are a lot of fun in the 5 years and 14,000 miles I have owned it
I think I saw you in your GN last Friday night??? On 81 northbound just south of Wilkes Barre? I was in my Brat headed to Pittston. I went to slow down to get along side of you again but some car was flying down behind me...
If it was you... It looked great in what light was still in the sky.
Old 08-15-2005, 09:37 PM
pnyklr
I wish it was the GN has been in storage since before memorial day - no a/c and it runs like crap in the heat .
