Old 07-20-2005, 10:40 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
alan
there are built in safety areas in a wrx for over boosting called fuel cut, its a wonderfull thing, cobb access port adjusts the boost to 16 psi i bieleve, why spend 600 for something that does it for 80.00 $ cobb doesnt do much in timing adjustments also or fuel curves in that matter,
if you dont know much abought tunning cars i would go with acces port its plug and play,
so far 23,000 miles on mine with no mechanical issues at all,
tim-h just mod one step at a time => cat back is a good start.
back on topic, this thing is going to hit 400 hp at the crank dammit !!!! LOL .
Originally Posted by Landshark
i dunno - i'm no expert at tuning turbo cars, but the concensus is that a CAI and a manual boost controller on a WRX is a good way to kill your engine. i'd do some research over at NASIOC first:
"mbcs cause part throttle full boost (ptfb) because you bypass the stock bc solenoid.... tap the throttle and you get full boost, even when you accel w/ cruise control. Not good - I'd strongly recommend not using one (unless you're really really educated and know EXACTLY what you're doing). Our 02s can handle them better than 04/05's, but you can still blow you engine by using one. But still... ptfb messes with the open/closed loop fuel system and that can = b00m"
"i'm not going to give you a bunch of crap about reading this or that. just understand that there are issues with using a mechanical boost controller that MUST be taken into consideration if you want your engine to be happy for any length of time. do searches and read and learn... or don't and possibly melt a piston or break a ring land or burn a valve.
i would recommend the Cobb Accessport ($650), an STi (~$200?) or gutted stock downpipe ($free). this will get you stage 2, and more peace of mind. you can change the uppipe for a quicker turbo spool up while you're in there if you like.
i would also probably upgrade the braking and suspension if you start adding the power........and of course, get new tires if the RE-92's are still on there.
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 07-20-2005, 10:57 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Nice!
(In the voice of Rob Schneider from the Water Boy) YOU CAN DO IT!!!!
-Chike
2006 Steel Gray WRX TR (sold)
Old 07-20-2005, 11:01 AM
alan
a MBC not being used with some other type of engine management is really asking for trouble. i wouldn't recommend that to someone.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 07-20-2005, 11:11 AM
drivemusicnow's Avatar
Poor College Racer
Originally Posted by Chiketkd
Nice!
-Chike
ALL NIGHT LONG!!!!!!!...
wait... nevermined
my dad has the accesport... its actually pretty cool... a bit expensive for what it is, however the tuning potential is rather large... i wish cobb would allow you to have them make maps for your specific situation though.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Chiketkd's Avatar
I've heard MBC's being run safely by using slightly higher-than-stock fuel pressure in open loop (e.g. increase of 5-10psi). This is of course w/o any engine management for the stock ECU.
-Chike
Old 07-20-2005, 11:19 AM
you guys have to rember, your only going from 14.5 psi to 16.5-17 psi not much diffrence there, the factory ecu has no problem with that type of adjustment for fuel and timing, now if your runing over 20 psi then you need to take over from the ecu and over 25 psi need a stand alone system AEM,,hydra,,motec,,micro tec and a few others out there,
of the MBC fails or spikes, it never does, if you buy a nice MBC you will knwo it in a hurry."fuel cut" and if it goes over 17 psi it looses its effeiceny verry fast. its more like pushing hot air then actually boost pressure,
acessport has come a long way though, even the options of downloading new maps for small turbo upgrades, it cant get any easier then that, and if your not familier with boosts or no boost gauge thats the route to go,
the UTEC system i have has that also, downloadable maps for basic set ups, and turbo's it is a 2 dimensional tuning system, the real stand alones are 3 dimensional i.e RPM=boost=FUEL it will take any 3 paramters and andjust's timing/boost//fuel acordingly.
the utec systems still runs off factory ecu until 50-60% throtle and then it takes over you can actually feel this. i also have the UTEC runing my methanol injection wich does a great deal in cooling the cylinder walls.
water injection take your pump gas 93 octane and puts it to 108 octane relativly speaking,
Old 07-20-2005, 11:47 AM
wait... nevermined
i believe you can make your own with their StreetTuner software.
Old 07-20-2005, 11:51 AM
with the AP, there are bonuses such as the Economy, Valet, AntiTheft, etc. maps you can flash if the situation warrants it.
also, you can un-marry it from your ECU, and sell it for only slightly less than you paid for it if you ever get rid of your car, so the price is a pretty good value considering.
Display Modes Rate This Thread
Rate This Thread:
