Old 05-22-2005, 03:09 PM
tailgatewagon
C to F change
well i was messing around checking and clearing the codes on my 94 svx. and i see a little white connector that hooked togethere, hum i unplug it and continue, well low and behold it changes the temp control to C insted of F, anyway probably old news but cool anyway.
Old 05-22-2005, 11:17 PM
sharky512345 sharky512345 is offline
Send a message via AIM to sharky512345
At first i thought you were asking how to do this and I was happy cause I actually knew the answer. But then I realized you knew how
Current: 2005 Black Legacy 2.5i 63k
Previous: 1996 Brilliant Red SVX LSi 117k
Old 05-23-2005, 02:19 PM
SVX_MY_BABY's Avatar
Now if we could only figue out how to make the Celcius setting work in half degrees. 21 is too warm and 20 is too cool
Old 05-23-2005, 03:57 PM
For me I usually leave it on 21 but sometimes 22.
Old 05-23-2005, 04:08 PM
NeedForSpeed NeedForSpeed is offline
If you switched it to F, would the system give you something between, or just the same increments onlly labeled in F instead of in C?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 05-23-2005, 06:22 PM
Keeping it in °F will give you more adjustments than °C
Now if we could only take the HVAC brain from a Nissan Altima and wire it into the SVX we wouldn't have this problem. A friend bought a 2002 Altima 3.5 and his temperature adjusts in 0.5°C increments.
Old 05-23-2005, 06:41 PM
Hi Dave, my 95 Australian model uses Celcius, and adjusts in 0.5degs steps, set at 22.5 degs C.
Harvey
Old 05-23-2005, 06:42 PM
Okay, so what's the trick to go from C to F? Is there a wire on non-US cars that can be plugged in to get to F? Are all non-US spec cars in Celcius?
Old 05-24-2005, 12:24 AM
THAWA
I think what he was asking was, it shows the different adjustments, but does it actually change it for each degree of F or does it change it for each degree of C regardless of what it is displaying?
Old 05-24-2005, 06:05 AM
Harvey
Now this is interesting. I wonder if we can modify our's or would have to replace the entire unit.
Old 05-24-2005, 06:10 AM
I've often wondered about this, but have a hard time wrapping my head around F, so never bothered to try it. Seems Earthworm has.
Old 05-24-2005, 07:00 AM
Clydesvx Clydesvx is offline
Way over-the-hill Member
This C to F and Standard to Metric confuses me also.
That's why I bought METRINCH tools!!
'92 LSL TEAL 277,000 miles
Trans (on # 3) Engine (on # 2)
"NEW" VISORS
'03 Forester XS 214,000 miles
'05 Outback 3.0R
Old 05-24-2005, 11:37 AM
The US/CAN SVX's don't have a ".5" on the readout. Each press for us moves 1° regardless C/F. I doubt we would be able to easily fit the JDM unit in our model.
The wire is hidden behind the driver's kick panel. It's a single black wire with a white stripe. If it's connected it will show °F and unplugged will show °C.
One way to find out is set it to as close to ambient as possible and see if settings change when you adjust by 1°F.
It may be possible to modify but we'd never see the .5 indicated.
I understand °F but I think in °C.
F=(9*C)/5 + 32
C=(F-32)*5/9
