Old 04-28-2005, 11:27 AM
remove the alternator and just pop the A/C off and it is really easy.
Old 04-28-2005, 11:33 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
I tried that last time. The A/C wouldn't come off. All the bolts were removed and it was free, but was wedged somehow. Just couldn't get it to pop out.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 04-28-2005, 11:42 AM
the bolts you need to remove are the ones holding the mount to the engine. Pull the whole assembly off.
Old 04-28-2005, 11:48 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Both of my knock sensors looked about the same as yours, David! (see my locker for pics of the removal and installation process). I'm guessing the wiring was extremely brittle on yours, too.
I found that using a "small part grabber" (you know, that thing in your toolbox that you only use when you drop a bolt down into the dark recesses of the engine...) extremely helpful when it came to installing the driver's side sensor (again, pics in my locker).
I used a racheting box end on the passenger's side and a socket on a universal joint and extension for the driver's side (you can come down between the intake manifold runners). I only removed the alternator.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
