Removal of Fuel Injectors
Does anyone have any advice (constructive, that is! ) on removing the fuel injectors from the fuel rail? I've removed the little half caps that hold them in place and I've checked my shop manual so I know they've got two o-rings sealing them into the "buckets" in the fuel rail. I just don't want to possibly chew up the plastic top trying to pull them out.
Thanks in advance for everyone's help. -Bill p.s. my plan is to send them off to a FI shop to have them blue printed/rebuilt/flowed, so we'll have actual test results for how well they flow
Re: Removal of Fuel Injectors
So, are you sending them to RC Engineering? I've been wanting to do that for a long long time. Looking forward to seeing the result.
Re: Re: Removal of Fuel Injectors
I think I'm going to use Accurate Injector Service (www.accurateis.com/) in Arizona. Good price and I've been emailing the owner, who's a Subaru fan! -Bill
Re: Re: Re: Removal of Fuel Injectors
-Chike
Re: Re: Re: Re: Removal of Fuel Injectors
Keeps me out of trouble (or, gets me into more trouble in the future ) -Bill
I've pulled them out a few times with just a twist and a large flat bladed screwdriver gently prying on the plastic part.
Where exactly do you pry on the plastic part? Thanks. -Bill p.s. I checked out a Q45 site (their fuel injectors are the same as ours - basically - except they flow 370 cc) and the consensus appears to be to grap the injector with bent nose vise grips - firmly, but not so much as to crack the plastic - and pry against the vise grip with a screwdriver while pulling up on the vise grip. Think I'm going to try to fabricate a tool to act as an extractor....
I checked out a Q45 site (their fuel injectors are the same as ours - basically - except they flow 370 cc) and the consensus appears to be to grap the injector with bent nose vise grips - firmly, but not so much as to crack the plastic - and pry against the vise grip with a screwdriver while pulling up on the vise grip. Think I'm going to try to fabricate a tool to act as an extractor.... [/B][/QUOTE]
Perhaps you could contact a dentist, Bill. Should be cheap, as there's no novacaine to worry about. Glad to be of help. Ron.
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
Ron,
Good advice, as always! I was thinking that a "box-o-wine" would also help the process -Bill
Turn the injector sideways so the part of the red plastic connector that you plug into is pointing towards the front of the car, then using a large screwdriver pry underneath it against the fuel rail.
Matt,
thanks -Bill
Hey Bill,
Did you get the fuel injectors cleaned yet? If so, did they give you the before/after flow rates for each injector?
Not yet. I decided to fab an injector puller and my machinist has been swamped lately. I'm hoping to have the puller done in a week and the injectors off to be cleaned/rebuilt/flowed by the end of the month. I'll let you know as soon as I've got data! -Bill
Maybe we can work a deal -Bill
