Old 02-24-2005, 03:23 PM
cmontee
transmission slips from 4 to 3
At normal cruising speed the transmission intermitantly slips from 4th to 3rd. It will shift back immediately if I back off on the accelerator. If in cruise control it will stay in 3rd for a while and then shift back to 4th. Question - is this a common tranny failure? Can this be remedied any way (other than replacement) Will it progressively get worse? *any comment, advise, ridicule or donations welcome!
Old 02-24-2005, 04:40 PM
lee lee is offline
anything been done recently? like a band adjustment or removal/failure of the dropping resistor?
Old 02-24-2005, 05:37 PM
cmontee
No, only a tranny flush (new fluid). I just read the other threads so will check out your sugesstions - Thanks!
Old 02-25-2005, 10:34 AM
One thing to look at is the Throttle Position Sensor (TPS). It may be sending a dirty signal to the tranny causing the downshifts.
Old 02-25-2005, 10:59 AM
n00b on demand's Avatar
How many miles on your SVX? Some members have had bad stories after they got a flush done on a high mileage SVX. Or was yours just a drain and refill?
Old 02-25-2005, 07:16 PM
cmontee
reply
142k. It was doing it before the flush. I will check the TPS and the resistor before I try a band adjustment. Thanks for the help!
