Old 02-24-2005, 01:33 PM
Sidewinder's Avatar
Sidewinder Sidewinder is offline
Send a message via AIM to Sidewinder Send a message via MSN to Sidewinder
Rust and the Solution
Hey Guys,
For many months now, I've had this problem. It's getting worse. Here in Wisconsin, its nearly inevitable, but it's rust.
On both the left and right doors, in the groove created by the door sheet metal fold and the body cladding, there is rust growing. It is growing down the crack from the front to the rear.
What, if any, solutions are there? Worst case senario: new doors. If that's the case, what do a new (used) set of doors go for?
Eric
1994 Bordeaux Pearl SVX LSi
"The SVX — Where, they wondered, do you put the kayak?"
Old 02-24-2005, 09:08 PM
mbtoloczko's Avatar
sans SVX
I've got rust in the same spot. I don't think it will be necessary to replace the doors, but depending on the extent of the rust, it may be necessary to fill in the hole with some weld.
Mychailo
Visit my locker
Old 02-25-2005, 03:38 AM
If you don't wanna go through the bodywork, get some sand papers, rub the rust off, and with a small painting brush, put some antirust liquid material on the metal, leave it to dry for a couple of days, then get the color of your car and put it over the antirust material...
Old 02-25-2005, 07:17 AM
mbtoloczko's Avatar
sans SVX
That's fine if the rust is minimal, but if its extensive enough, either Bondo, or preferably weld filler is needed.
Mychailo
Visit my locker
Old 02-25-2005, 07:30 AM
I was giving an opinion related to the pic... the rust doesn't seem very huge.. yeah of course if the rust is extensive, nothing will fix it except a bodyshop...... and Bondo is not good for the long term...
Old 02-25-2005, 01:22 PM
For a longer term fix it would be best to cut out the rust and weld in a new piece, zinc coat it then paint.
Old 03-03-2006, 04:45 PM
TCamusJr TCamusJr is offline
I've got rust in the same place...sigh. Must be another unique quality of the SVX.
Maybe some lemon or/and vinegar water and a good scrubbing would help.
Old 03-03-2006, 05:00 PM
michael's Avatar
michael michael is offline
What Potholes ???
If you can see it with the panel on it proably looks like this
Wanted: Steering Wheel
Old 03-03-2006, 10:29 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
When I used to work with iron men, they used a special paint that can be applied right over the rust without scraping or sanding. It would stop the rust process and change it to a solid form. It was used on I-beams. I don't remember the name, but I'm sure if you do a search, you'll find it. Good luck.
Old 03-04-2006, 01:03 AM
Crusader's Avatar
Crusader Crusader is offline
$13000 and counting...
Send a message via AIM to Crusader Send a message via MSN to Crusader Send a message via Yahoo to Crusader
I've also had recommendations for fiberglass after sanding away the rust in place of bondo
Old 03-04-2006, 05:40 AM
michael's Avatar
What Potholes ???
I believe it's POR 15. From what I hear it's amazing.
