Old 02-23-2005, 11:55 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Oil coming out of the exhaust.
The racer has oil dripping (well more of puddling) out of an exhaust hole before the first cats. Any ideas. Running a little rough but there really isn't much blue smoke. Definately some white smoke but that could be from the bad gas/deet that is in it to get it up and running from sitting.
Idle is definately a little rough, no dash to see any dash lights , hesitates when stepping on the gas.
Old 02-23-2005, 01:45 PM
You should at least hook up your CEL so you can check for codes.
Old 02-23-2005, 02:21 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Ben,
given all the room you've got to check on the engine I'd suggest pulling the plugs to see what shape they're in...my guess is you'll find at least one that has some serious oil fouling (unless the SVX's super-duper coils are burning it all off the plugs, in which case you'll have to pull the plugs and see which holes have oil blowing out of them when you crank the engine over....).
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-23-2005, 08:40 PM
benebob's Avatar
Plugs are brand new so they probably won't have too much. It seems to have diminished so we'll see if it burns it off.
Old 02-23-2005, 09:12 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
I don't think it'll hurt to pull the headers and clean everything out with brake cleaner.
If the oil is leaking less and less though, that's a good sign. Any plans to patch that exhaust hole? Some JB Weld outta do the trick.
-Chike
2006 Steel Gray WRX TR (sold)
Invisible avatar
Cool
Come on, Ben, oil leaks are never a problem as long as you can pour more in faster than it drips out.
See you at the strip.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 02-23-2005, 09:15 PM
Chiketkd's Avatar
LOL!!!
-Chike
