Old 01-13-2002, 01:03 PM
htyei's Avatar
htyei htyei is offline
SVX Animated Icon Guy!
Send a message via ICQ to htyei Send a message via AIM to htyei Send a message via Yahoo to htyei
Brake Pads
To to replace the front brakepads with 10% in the front and 40% in back. My next autocross should finish it off.
Now the question is, what kind of brakepads are you guys using?
Thoughts on oem(best?) and others would be great.
Whats the compositon of the oem pads? semi-metallic, regular?
I've also had quotes ranging from a 2 regular shops for 175 for doing front brakes to a quote of 220 for front and back at the neighborhood (hole in the wall) shop.
Henry Yei
htyei@svxwrx.com
1992 Dark Teal LS-L w/o spoiler "OLIVIA"
http://www.svxwrx.com
Old 01-13-2002, 01:13 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
this is the info i had from about 2 months ago
pad -- 25 pair -- dealer / 1 year
pad -- 20 pair -- autozone / lifetime
pad -- 22 pair -- bluestar / 1 year
rotor -- 150 each -- dealer / 1 year
rotor -- 75 each -- autozone / lifetime
rotor -- 55 each -- bluestar / 1 year
my numbers.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 01-13-2002, 01:44 PM
htyei's Avatar
more questions
Subaru Parts Brake parts List
What does the the Disc Brake kit come with? More specifically, exactly what parts should I buy if I were to take it to a mechanic or do it myself? (change front disc brakes
Henry Yei
htyei@svxwrx.com
Old 01-13-2002, 04:21 PM
slybry
The factory disc brake kit comes with the pads and all necessary shims to do the brakes. It also comes with grease to lube the notches where the pads slide along the calipers. It's an easy job to change pads and to take off the rotors and have them turned. Some will recommend not turning your rotors because they feel that with less thickness to the rotor, it will warp easier. I had mine turned about two thousand miles ago when I replaced my pads and haven't had any problems since but I'm also pretty easy on my car.
Old 01-13-2002, 04:27 PM
slybry
Just to clarify. The parts I described in my last post are the ones included in a disc brake pads kit not the disk brake kit. It appears that the disc brake kit includes new or rebuilt calipers as well. Depending on how many miles are on your car and what kind of shape the existing calipers are in, you may want to get new calipers as well although mine were in good shape and I just replaced the pads.
Old 01-13-2002, 05:12 PM
htyei's Avatar
AH! Iwas wondering why the disc brake kit were so expensive! Thanks!
Henry Yei
htyei@svxwrx.com
Old 01-13-2002, 05:59 PM
Jamsvx's Avatar
Jamsvx Jamsvx is offline
Send a message via ICQ to Jamsvx Send a message via Yahoo to Jamsvx
Toyota Dyna pads
I met an SVX owner here a while back who told me that the brake pads for the Toyota Dyna light van are the same as those as on the SVX...and considerably cheaper than OEM.
I am not sure whether the Dyna was marketed in the US or Britain but thought I would throw this in.
Regards
Jamsvx
1992 charcoal grey SVX:
27 August 2002 to 27 January 2004 - she will be missed
Was back in Sydney for a while but not hot enough so now in Dubai! Has it been that long since I owned SVX-33H!
