Old 02-05-2005, 11:36 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
belt squeek? WHY!!!!!!!!!!!!
i have a sliping belt and i just got it back from the shop. could this be a result of thermal expansion/shrinkage and the general loss of friction due to cold? do i have to get my car looked at again or can i wait till spring? I CANT TAKE THE NOISE. AHHHHHHHHHHHH it sounds like i have a million rodents stuck in bear traps under my hood.
Old 02-06-2005, 12:13 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
What work did the shop just do to your car ?
could be lots of things and could be one of 2 belts.
Could also be one of the tensioners dry or wearing out
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 02-06-2005, 12:31 AM
they replaced not only the idler pully but the entire plate the pully mounts to (the shop i used to go to over tightned the belt so much that it bent up everything.) it work fine for about a week then it started to snow and get rainy and cold and bam, horid screeching that would make a sane man homicidal. (im not by any means sans so you can imagine what its doing to me every time i start it) its worse right when i start it and after abut 10-20 min of driving it subsides to a point.
Old 02-06-2005, 12:36 AM
Sounds like they installed the wrong size belt...
but only maybe 1/4" or so....but Id take it back
and let them hear it, ...pull it off, check the size and get
one about .50" shorter
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 02-06-2005, 04:43 AM
i'd take it to a dealer, because this place sounds like a Mickey Mouse operation.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 02-06-2005, 10:07 AM
Ive known some "dealers" to be mickey mouse too..
Not to mention you already paid the others guys to fix
your car.....go back and have them rectify the problem
and get what you paid for if you ask me.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 02-06-2005, 10:34 AM
kuoh kuoh is offline
I'm guessing they fouled up the tensioner on the PS bracket because they forgot to loosen the position lock before attempting to loosen the tensioner. It's pretty much the only way you could screw up that bracket. Are you sure they replaced both the bracket and the idler? They should both look new. If they did replace them, are you sure they installed it properly and the pulleys are lined up with the crank pulley?
Another possibility is that the idler pully on the AC belt is going out as well. I had this one lock up making that shrill squeal for a minute, until it snapped and went into one of the radiator fans.
KuoH
Old 02-06-2005, 11:31 AM
Rotorflyr's Avatar
What he said
2006 B9 Tribeca
Old 02-06-2005, 11:37 AM
Originally posted by Rotorflyr
What he said
and take with you what Kuoh suggested and
you should be fine.
They may even learn something
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 02-06-2005, 03:16 PM
Maybe they didn't tension the new belt as much as they should, due to the previous trouble. Now that it has bedded in, its sipping, just needs retensioning .
Old 02-07-2005, 05:07 PM
Check the tension yourself, if it's fine then perhaps one of the accessories or idlers is worn out?
