Old 02-19-2005, 01:32 AM
deruvian
Originally posted by ensteele
With the filters that I have helped change, the magnet looked the same as you describe. The more sludge, probably the longer time between filter changes. I would guess that most have never changed them.
Phew! That makes me feel better.
Old 05-09-2013, 03:50 PM
theflystyle's Avatar
Re: Transmission - Internal Filter Change
Awesome guide, but I have gone to two different stores and the filter in the FK-237 box is the square one. I cant find the one pictured
1994 SVX LSi
2008 Legacy 3.0R
Old 05-09-2013, 06:48 PM
longassname's Avatar
Just some dude.
The filter it shows coming in the kit is the wrong filter for our cars anyway. It's one of the short pickup tube versions which were never used on the SVX.
If you look at the original filter you can see the longer pick up tube which reaches much deaper in the pan to pick up fluid. That is the correct filter for our cars.
The "black grime" isn't a problem. That's just normal wear and it doesn't clog the screen. Now, what you see on the screen of that filter is a different story. It's full of "stuff." That means at least one friction has disintegrated.
Old 05-09-2013, 07:01 PM
http://shop.advanceautoparts.com/web...ing_18150479-p
That's the one I am talking about. There is no curved portion, its just all flat.
1994 SVX LSi
2008 Legacy 3.0R
Old 05-09-2013, 07:33 PM
That's a phase 2 filter kit
Old 05-09-2013, 07:44 PM
This appears to be the right one:http://shop.advanceautoparts.com/web...ley_18025933-p
PS. Same part is only $19.07 plus a couple of bucks shipping at: http://www.rockauto.com/
Old 05-09-2013, 08:09 PM
Yep, make sure the o-ring comes out with the old filter, or you might have to reach up and grab it.
BTW, I posted this in another thread, but it's fitting here. This is what a clogged filter looks like to the point where it allows ZERO line pressure and no movement in any gear.
Old 05-10-2013, 01:32 PM
Thanks for the good info. When I was at the two Advance Auto stores, neither had the beck filter available unfortunately.
I also have AutoZones nearby and they apparently have a Duralast filter in stock as well. I will hit those stores up next and see what they look like out of the box.
http://www.autozone.com/autozone/par...er=898028_0_0_
1994 SVX LSi
2008 Legacy 3.0R
