Old 02-05-2005, 09:42 AM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
door locks
Hey, my door locks won't engage or disengage on the driver's side, any ideas on how to fix em or should I just order a new solinoid?
98 Impreza Wago-O-Doom & Datsun Roadsters
Old 02-05-2005, 02:53 PM
lee lee is offline
it's probably the motor assembly. Unfortunately, it can't be bought by itself and you have to buy the whole assembly. less than $130 tho, so not TOO bad.
Part # 2 on this page
http://www.subaruparts.com/diag/?mod...category=602-A
Old 02-07-2005, 02:43 PM
check for a loose connection first.
Old 02-07-2005, 05:17 PM
curly2k3's Avatar
Own'eded
its not a loose connection, checked that yesterday.
Old 02-07-2005, 08:03 PM
So the plug right by the actuator is getting the proper voltages? Another test is to send power directly to the actuator. That's what I did to determine the short in my door locks.
Old 02-08-2005, 07:22 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Open up the solenoid and check for water inside. If there is some then empty it out and spray the contacts with WD40.
I've had this a few times where it causes the solenoid to stop in a halfway position and then you can't lock or unlock the doors.
Phil.
