Old 02-02-2005, 02:29 PM
garybarlow
transmission replacements
"For those contemplating parking their own SVX in the home garage, there are only a few mechanical problems to look out for - transmission wear, noisy wheel bearings and warped discs. It is said that adding a fluid cooler extends transmission life but, in any case, transmission replacements aren't too expensive. It appears that the auto transmission that comes attached to JDM import Liberty twin-turbo motors is very nearly the same as the SVX's and potentially interchangeable - these are often available very cheaply, since most people transplanting a twin-turbo motor usually ditch the auto trans. Note that we've also seen complete JDM SVX half-cuts for $4500."
Is that true? Anyone knows about it?
Can we really replace SVX tranny with Liberty's?
Old 02-02-2005, 03:58 PM
Re: transmission replacements
Hi Gary, yes the Liberty trans will fit the SVX.
As far as the Twin turbo unit being the same? I doubt that it is exactly the same. Does it have VTD AWD or the Transfer AWD? The SVX has an extra clutch plate in the high clutch, that the non turbo doesn't.
Joe has a couple of Twin Turbo Legacys, he may know what the differences are. I think it was David in Brisbane that talked about getting a front cut? not sure.
