Old 01-25-2005, 08:10 PM
nick_06
Antenna
I already searched for this and couldn't find it. If it's there, then my fault, but please don't reply to this by saying "The search bar works wonders". Anyway, Im not getting power to my antenna and it wont retract, anyone have any ideas?
Old 01-25-2005, 08:45 PM
n00b on demand's Avatar
I wonder if it could be a wiring issue ....u know alot of audio places are shocked when they see the SVX has a power antenna...i have no clue why their so shocked.
Old 01-25-2005, 09:00 PM
lee lee is offline
when you say power, do you mean 12V power or signal from the radio?
There's three wires going back there (or so I remember). One is at ground (black), one at battery level (white) and one that gets a signal from the radio (black/green?).
Old 01-25-2005, 09:16 PM
SubaSteevo's Avatar
No longer blue member
Stock or aftermarket radio?
Just started?
Dumb question...how cold is it outside? On more than one occasion I've had my antenna freeze while in the up position.
-Steve
01' MSM Lexus IS300
Old 01-25-2005, 10:38 PM
Open the trunk and listen to see if there are any sounds when you try to make it retract. If so, maybe the plastic part is not hooked into the motorized part. Look in the How-Tos and see what it looks like in there and you may also have to clean and oil it. Good luck.
Old 01-26-2005, 05:25 AM
Sybaris Sybaris is offline
Is that also a reason why it will partially retract?
Mine will only go about half way down.
1997 Bordeaux Pearl LSi ~45K
Old 01-26-2005, 06:43 PM
nick_06
The antenna is completely up. It makes no noises whatsoever and it just happen out of the blue. It wasn't a gradually thing where it would stick a little and then it stopped completley.
Old 01-27-2005, 06:11 AM
dcarrb dcarrb is offline
It's definitely a loose/faulty connection, then, or the motor's fried. If it were a mechanical problem with the antenna retraction mechanism, you'd still hear the motor. I'd start by checking/cleaning the connections at the motor.
dcb
Old 01-29-2005, 12:56 PM
svxstarship svxstarship is offline
Have you checked the fuse yet?
Old 01-29-2005, 03:41 PM
nick_06
I havent checked the fuse yet. Where is it located?
