Old 01-18-2005, 07:52 PM
matt matt is offline
Send a message via ICQ to matt Send a message via AIM to matt
Hub Tamer pieces?
Which parts of the OTC set are needed?
How does this one from Harbor Freight seem?
http://www.harborfreight.com/cpi/cta...emnumber=45210
86GN
95SVX
81RX7/302
Old 01-18-2005, 09:19 PM
lee lee is offline
Matt,
I used a Hub Tamer on the rear bearings and the Harbor Freight tool appears to have all I used, but then I really had no idea what I was doing & just fumbled through. For example, I found no use for the big "C" shaped thing in the OTC product, and since there were no instructions in the one I used I can't say if it would be needed for front bearings or other kind of car, etc.
Old 01-21-2005, 03:00 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
The "big c" thing is used to press the hub out of the bearings.
Old 01-21-2005, 09:20 PM
lee lee is offline
Like I said, I fumbled through it. I somehow managed to set up a combination of the metal sleeves that fit & worked using the long bolt to draw/push.
The really bad part - now that Beav points out the real purpose - was I asked the base auto skills center "advisory" mechanic what the "C" thing was for and he was clueless. Kinda makes me cautious about getting future advice from him.
Old 02-07-2005, 03:48 PM
so would this kit then be suitable for the svx front and rear bearings?
Old 02-10-2005, 01:57 PM
alia176 alia176 is offline
I agree, the big C thing is a bit of a pain to use and doesn't like to sit squarly. Using a slidehammer that can be rented from Autozone could be used to pull the hub out. The tool looks similar to http://www.harborfreight.com/cpi/cta...temnumber=5223
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 04-07-2005, 12:24 PM
SO does this kit include everything needed to do the bearings or should i get the hubtamer....
Old 04-07-2005, 01:39 PM
Yes, this kit will work.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
