DSM tuning ideas
So i'm finally getting serious about building up the 93 eclipse GSX you see in my signature. I've been on some other forums and have been doing a lot of research, and just wanted to also post on here to get some ideas...
for now i'm limiting the budget at $2k. my plans for the car are for the next couple years build it up with that $2k, such that its a great track car for the money. Then after college, i'll either keep it and put more money into it, or sell it and try to make at least $4k out of it. I'm going to be rebuilding the motor due to the high mileage (155K) but i don't think i'll be upgrading the internals, just bearings, seals t-belt and the like. I would like to know some of your thoughts on parts out there for dsms. I'm thinking that i'll just custom make the exhaust, 3" all the way back (i need something thats non restrictive but brings sound levels WAY down.. i was thinking maybe a resonator before the muffler? Right now i'm kinda just putting together a plan of attack. Anyone have experience with different turbos on a dsm? Think i'm just going to go with a evo3 16g... even though the garrets are better turbos you end up spending more on modifications to install them
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
Hey, saw your post on tuners yesterday..
What I would do is rebuild the engine using 1g rods and 2g pistons. The 1g rods hold alot more boost, and the 2g pistons give you a little more compression for more torque. If you're going to go with a 16g, you have a few choices. You have the regular 16g, then you have an evo III 16g, and a big 16g. Which one you want depends on hp goal. I personally prefer to have a quicker spooling turbo that will spool around 3k rpms instead of a huge monster that will spool at 4.5k since our redlines are at 7k. Since I have a 2g I'll be going with a T28 killer as my upgrade. Before you decide on which turbo you want, you'll have to figure out all that will be needed to replace to get everything ready for that bigger turbo. Front mount intercooler or side mount? What clutch? Fuel pump and injectors? Datalogger? Boost controller? dsmtuners.com has ALOT of information on all these subjects. Good luck with the DSM!
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs. http://stickyvinylgraphics.com/ |
Oh, and when I state 1g rods, I mean from a 6 bolt motor
Also, you could get some head work done for pretty cheap.
Cheap manual boost controller. I think i'll go with an Ebay special FMIC (saw one for like 675$ for a full kit.. looked like what i want. stock clutch until i kill it then probably a cheaper ACT, walbro 255 LPH pump, and no idea what brand but 550 injectors. No data logger because i don't have the money, so i'll be very careful tuning with gauges and possibly borrowing a data logger from a friend occasionally... are all 2gs OBDII? (ok.. something i still haven't figured out, what years have 6 bolts, and what years have 7 bolt engines... i thought just 1gs had 6, and 2gs had 7s.. but thats starting to not make sense) Thanks for any help
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker Last edited by drivemusicnow; 11-18-2004 at 12:52 PM. |
if the engine is in good shape,, no need to tear it apart to rebuild it again just for 2g pistons and such, whene or if it does let loose then go for the nice engine goodies,,
as for mods for basics,, 3" turbo back //intake//MBC are the bare essentials . also crush your 1g bov to hold more boost as for turbo set ups 14bs are pretty good u can get in the12s with it,, the next thing for less lag and good power is the 16g there cheap and good cfm flow aroun 550 cfm depending on size. also a must is a 2g exhaust manifold and prot it out to 7cm for better flow zeppelin i loved my t-28 from forced performance good turbo, verry little lag and flows just as much as a 16g .also rember if u upgrade the turbo 16g wise,, injectors//pump and such are needed and also a must on that list is a super AFC tuning or dsm translater and gm MAF conversion all helps out
2008 evo x with sss package 430 hp 380 torque stock turbo with basic bolt ons 12.56 @ 109 fully weighted 3,500 lbs |
The engine has 155K on it and hasn't exactly had perfect upkeep.... It still a strong motor, however... i think a rebuild with seals, orings, gaskets, (not sure about when the T-belt was replaced.. but i can find out) bearings will help get the most out of the engine. I do not think i'm going to buy ARP bolts though.. seem Way too expensive. But I'm thinking its probably going to come down to "open it up and see"
I'm thinking the 3 inch exhaust shouldn't be that hard to make myself (with a little help from friends and possibly a shop), i just can't do the mandrel bends... i just REALLY don't want to buy a pre-made one cause they mostly sound like crap.. and loud whats the "how-to" on crushing a BOV?
do a compression check if it checks out,, its ok,, jesus ran in the 11s with 180k on his engine,
also do not,, i repeat do not make your own exhaust, ,, buy one already made,, a nice 3" downpip and any cat back long as it is 3" and do not have a muffler shop make it, u want manderal bent piping. if u are dead set on making your atleast buy a nice dp. u crush the cap of the BOV go to dsmFAQ should find something
Check out www.vfaq.com for lots of tech articles. Crushing the bov is covered under the intake menu.
The 6 bolt motors were years 90-92.5. The 7 bolt motors are 92.5-up. The way to tell is to look at the oil pan on the driver's side. The oil pan will sink into the motor on the 6 bolts, and bulge out slightly on the 7 bolts.
VRS Or you can order the pieces separately from there as well.
Todd
Down to none |
Yeah, he's doing more than just building hotrods now...maybe it's a mid-life crisis thing.
but wouldn't i be better off replacing somethings like the original headgasket thats currently in place, o-rings and the like? or would i just be wasting my time
I say work on the Suspension, Brakes and exhaust for the time being... Get those worked out nicely then start getting into the Engine Ya always want something that can corner and stop atleast 2x as fast as ya are planning to accelerate
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
Maybe if autocrossing... but i'm thinking more of just a fun car... to play with... and learn how to build it up... i'll doo suspension, i just have a limited budget.. and the stock turbo has 155k on it... on a normal car, i'd totally agree with you... but this is just gonna be a fun learning experiment right now
oh, and vfaq.com is awesome... quality info!!
tires, tires, tires. Spend the brunt of that money on tires
