Old 11-04-2004, 01:36 AM
Sonar's Avatar
Sonar Sonar is offline
Andy, check the size of the .IMG file, it should be approx. 3,92 GB (4*219*371*520 bytes) !!
If it seems ok, there are plenty of burning programs that can burn a .IMG file to a DVD, I use "Veritas RecordNow" and Earthworm seems to use "DVD decrypter".
-What does GhostRider do?
-Well EVERYTHING imaginable you should NOT do if you want to survive at least more than 5 seconds on a bike!
-Example: going close to 200mph on HEAVILY traffic road ....
...or... visit the local police academy training center....and...well you'll see
In other words, a school example of what to NOT do!
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 11-04-2004, 08:25 AM
mbtoloczko's Avatar
sans SVX
Originally posted by Sonar
[B...
here it is: ftp://svx:boxer@193.13.42.40:9921/Gh....DVDR-XSTREEM/
...and remember, PASSIVE mode FTP , just in case, but not necessarily needed because this server is NOT firewalled
/Sonny [/B]
Can you put the monolithic (3.9 GB) file on this server?
Mychailo
Visit my locker
Old 11-06-2004, 02:04 PM
Sonar's Avatar
...Ok, in progress ....
check root level of .IMG file
/Sonny
Old 11-06-2004, 02:16 PM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
All up & running. I have only had time to watch the 1st 10 minutes. 300kph through the rush-hour traffic. Knutts.
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 11-06-2004, 08:51 PM
mbtoloczko's Avatar
sans SVX
/Sonny
Found the file, but now I'm getting a maximum session timeout disconnect.
Mychailo
Visit my locker
Old 11-07-2004, 03:46 AM
Sonar's Avatar
-Oops, sorry Mychailo, I forgot to remove one prechecked option "Session Timeout 5 min." ...
-Now fixed
/Sonny
Old 11-07-2004, 10:42 AM
mbtoloczko's Avatar
sans SVX
Thank you. :-)
Mychailo
Visit my locker
Old 11-07-2004, 11:20 AM
Andy's Avatar
Now also available on eMule
Andy
Old 11-10-2004, 02:14 PM
mbtoloczko's Avatar
sans SVX
-Now fixed
/Sonny
I've found that the 5 min limit is has been removed, but your server is still consistently booting me after about 2-4 hrs. Any chance you can fix that?
Mychailo
Visit my locker
Old 11-10-2004, 03:04 PM
Andy's Avatar
See post above
Andy
Old 11-11-2004, 04:46 AM
Sonar's Avatar
I just can't figure that one out
Looking in the log, everyone seems to get booted after 2 hours and a few sec's.
I can't find ANYTHING that effects that
The only thing was that preconfigured value of "session timeout = 5 min."
I just putted a zero (0) in there, now I have putted 1200 minutes, maybe that would help
The "Idle timeout" is set to 15 min. & "Max sessions" to 5.
An alternative is to download the .RAR files, file by file.
/Sonny
Old 11-11-2004, 09:28 AM
mbtoloczko's Avatar
sans SVX
/Sonny
Hi Sonny. Thanks for checking. Hopefully setting the session time to 1200 minutes will fix it. It will be interesting to see because when it boots me after 2 hrs, I don't get the same message as when I was getting booted after 5 minutes. After 2 hrs, I get a msg saying the server has been shut down whereas for 5 minutes, I was getting a session time exceeded message.
Anyhow, no problem for me getting the big file even when getting booted every 2 hrs. My ftp program as resumable DLs.
Mychailo
Visit my locker
Old 11-11-2004, 05:40 PM
mbtoloczko's Avatar
sans SVX
Setting the timeout to 1200 minutes didn't fix the problem. Still getting booted every two hours or so. Could it be something related to your ISP?
Mychailo
Visit my locker
