Old 05-05-2004, 05:46 PM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
NEED HELP FAST!!! look please
i need a scan of probably page 84 and 85 of the svx service manual... i have a legacy one, and the part of the manual that i need is section 3-2 (automatic transmission and differential)
REMOVAL AND INSTALLATION
1. shift solenoid, duty solenoid and valve body
i need this part, and i specifically need the part about removing the valve body as a whole, not in two pieces... i need to know which bolts to remove... they're different from the legacy
SV What?
Old 05-05-2004, 06:35 PM
NomadTW's Avatar
never mind, it was the same, the diagram was just weird looking
rant:
when you make a diagram for something in sequential order... if you removed a part from the unit in a previous step, do not include that part in the diagram at a later point in the process
the oil strainer pan was removed in step 5 (incl diagram on how to remove it) step 6 was remove the control valve body, in the diagram the oil strainer was still pictured, with bolts needing removed being pointed to behind theoil strainer!!!
SV What?
Old 05-05-2004, 06:38 PM
lee lee is offline
Always glad we can help
