Old 04-20-2004, 10:52 AM
glide glide is offline
How do I clean suede?
I was in the middle of a nice long drive back from Columbus over Easter, when my girlfriend looks at me and says "I'm sorry". At first I was confused, then I saw the 2 inch long blue pen mark going down the passanger side door handle, the suede part.
I managed to stay some what calm, and said "you should be". Anyway, does anyone know how to clean ink out of suede or do you know anyone with part of a door panel for sale?
Old 04-20-2004, 11:01 AM
MNYPNNY's Avatar
MNYPNNY MNYPNNY is offline
FKA....thndrmtn92svx
Alcyone Silver Contributor
Send a message via AIM to MNYPNNY Send a message via Yahoo to MNYPNNY
I have a passenger side door panel in great condition for sale. PM me if you're interested.
~~Michelle
'92 LS-L - copper - 190K miles
'94 LS-L - pearlie - 92K miles
*still have '92 parts*
Old 04-21-2004, 09:36 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Use woolite and some warm water. Its what i use to clean mine and I think the subaru manual recommends a mild soap and water. Hope this helps
~Ray
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 04-21-2004, 11:32 AM
NeedForSpeed NeedForSpeed is offline
Ask your Dry Cleaner for advice.
Buy your girlfriend a pencil.
Old 04-21-2004, 12:20 PM
michael's Avatar
michael michael is offline
What Potholes ???
I used upholstery cleaner from the auto parts store blue coral I think, spray it on let it soak for 15 min. then blot it with a clean dry towel. What ever you do do not scrub it or it will ball up, if you must scrub it and it does ball up a little, use a shaving razor to remove the excess material.
Wanted: Steering Wheel
Old 04-21-2004, 12:47 PM
mark10t
I've used carbochlor (trichloroethane, carbosolv?) solvent (it's basically the 'politically correct' version of the old carbon tetrochloride- dry cleaning fluid) on my door panels when they get a little dirty from repeated contact with slightly dirty or greasy hands. It's worked well for me by rubbing out with a clean cloth and haven't noticed any ill effects.
-Mark
Old 04-21-2004, 07:37 PM
JLittell
Thumbs up
Solvents, chemicals, or any liquid base requires a lot time. Use a wire brush and lightly brush the escaine. Some will beg to differ but this is a great way to keep it looking new. Try it!
