View Poll Results: Which one of these SVX electric features is your favorite? | |||
Bright switch on the end of the blinker stalk for brighter dash lights. | 21 | 35.59% | |
Shutoff timer for the RECIRC and rear window defroster so they turn off when forgotten. | 0 | 0% | |
Digital climate control for the cabin with display for that just right temperature. | 24 | 40.68% | |
Fog lights that shut off when the high beams are on. | 0 | 0% | |
Outside temperature button and display for the "What's it outside?" knowledge. | 7 | 11.86% | |
Two position wiper parking, one for looks and one for use. | 7 | 11.86% | |
Voters: 59. You may not vote on this poll |
Thread Tools | Display Modes |
#31
we should add 'other' to the poll. i like the map lights that do not kill your battery if left on over night . also those map lights can be on at night and not compromise your vision at night.
#32
dont forget
dont forget the quick access of the floppy sunvisers they are auto too when u need them they just flop right down (hmm on my car though the just always come down even when not needed)
i tryed to vote for outside temp cause im just to lazy to open my window and guess the temp...im i doing something wrong that i can never get in on a poll i try to vote but never works hmm oh well Jim out |
#33
Re: Climate control, definitely
The "bright" switch they are referring to is not the same as the dash brightness control. When you turn your headlights on, your radio, clock, shifter console, and climate control panel all dim. The "bright" switch at the very end of the headlight control switch makes those items bright again. This is handy when you want to drive with your headlights on in the middle of the day without making your clock impossible to see. Dave |
#34
"bright" switch
Diana 1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint |
#35
The law is more then 2 pairs of driving lights. The light bars on top of trucks are not driving lights. They are safety or visibility lights.
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
#36
2 brilliant features not mentioned:
I absolutly love the light that is around the key hole on the drivers door. Simply pull up on the handle and vwala you can put the key in the hole without scratching the paint (this feature is especially nice for those of us with the security control module that secures itself permanently)
The other feature is the big light ring around the key hole on the interior! It just makes my life sooooo much easier! ~G |
#37
hmm
now if they only did the trunk with that light i would be happy...have a small switch u press around plates and poof light on key hole
Jim |
#38
Which feature
1. bright /dim button on the stalk ...luv it
2. glove box...light ...OK is there one ..where's the switch/bulb 3. I luv the beep when car is locked when you lift the handle 4. summer/winter wiper button ..hit it now and again when dismounting bugger !! 5. the jack is compact and nifty ..I like that, works a treat 6. climate air ..recent 42C heat with 90% humidity worked a treat..good enuff to fog the glasses on exit from the car..!! 7. spoiler roof open it to see about 0.5 inch of sky ..great breeze on the thinning scalp..also defogs recently fogged specs..!! D2OZ
Dave Down Under |
#39
Re: Which feature
Is that a feature of the car itself, or the alarm system? Jason.
1992 Charcoal Grey SVX - 165,000km 1992 Ruby Red SVX - 165,000km ....now with sequential VIN numbers! 1986 Holden (Isuzu) Piazza Turbo - 225,000km 1993 Mercedes W140 S500 Coupe - 153,000km 1990 Mercedes W124 300D - 313,000km EG33 + 4EAT + VTD AWD = SVX |
#40
Re: Which feature
dcb |
#41
Re: Re: Which feature
If I'm not mistaken, some of the European models had a "door latch code" for the Security System. Kind of like a "morse code:" by lifting the door handle in a certain sequence you could lock/unlock the doors and set the alarm. Could someone please confirm.
#42
Both 95 builds
JDW - SVX ...both cars one with alarm one without both with beeping drivers door handle when lifted..
Aredubjay ... yes in Oz although I haven't tried it, it is mentioned in the car manual that programming the handle via lifting it up and down in a sequence.....with your tongue hanging out to the right !! so that if you locked your keys in the car ..you will be able to get in !! To Oz owners - do you have a glove box light 2 cars ..no apparent light ..even after standing on my head for several minutes Unmentioned feature - the pre planning fuel gauge...fast reacting to impress on the driver to fill...just how long do you run with the fuel light on ??...and even when the gauge is on Empty ..who fretts when the fuel light doesn't go on and its been ages with the needle on empty..is the bulb blown ?...then it comes on ... has anyone ever fixed this part of the SVX 'character' !! Dave
Dave Down Under |
#43
Re: Both 95 builds
However, I do have a glovebox light! It is located just behind the latch plate at the top of the glovebox. Note that the light does not activate unless the ignition switch is in the "ON" position! Jason.
#44
Re: Both 95 builds
My 1992 owner's manual does not mention this feature at all! I am therefore assuming that the door handle "beep" is linked to this feature, and that would explain why my door handle is silent.....! Jason.
#45
Re: Re: Re: Which feature
paddlesnz 1993 Subaru Alcyone SVX 1980 Isuzu 117 Coupe Giugiaro Edition 1999 Mazda Astina 2006 Honda Legend 2006 Toyota Mark X Premium 2007 Toyota bB 2007 Mazda Roadster RS 2012 Peugeot 208 Allure |
