Old 03-15-2004, 03:39 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Nighthawk 650 is home and starts... almost
Picked up my new addition on Saturday (an 83 Honda Nighthawk 650). Spent the past couple of hours bleeding the clutch and prepping it to start. Well I toasted the battery charge but I got her to fire up and then die. Not bad for a first attempt w/o knowing what was done to the gas. Now I just have to wait for the trickling charger to do its job.
Any ideas other than draining the gas?
Old 03-16-2004, 11:00 AM
ww111
Pull the float bowls and use gumout liberally... also, and this could be a pain. Gain access to the slides and spray them and make sure they move up and down like they should. new plugs and 1 teaspoon of oil in each cylinder. After that, it should run fine. If it hunts for an idle speed, sync the carbs.
Collins
Old 03-16-2004, 11:44 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Starter fluid sprayed directly into the air intake?
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-16-2004, 01:51 PM
benebob's Avatar
She's a running. Too bad its snowing. Not a good day for a ride. Besides, I guess I need to get a permit huh. Just a little carb cleaner did the trick. I also changed plugs but the old ones looked fine. Just had to get a 18mm plug socket so got new plugs while I was at the parts store. I guess Saturday will be the day to change the oil and spruce her up. Then RIDE!
