Old 01-15-2004, 09:14 AM
[BrUn]
ABS dash light + dead battery
Last night, my abs dash light come up but the abs system was still working (it was -26 farenheit outside). This morning my battery was dead, I didn't forget any lights inside. ( The car pass the night outside at -29 farenheit) I don't know if it is related or not, maybe the abs system was still working even if my car wasn't running and decharge the battery??? I boost it and it take many try before it started. The day before it was -22 farenheit and the car start at first try.
Any idea of what can have cause this?
Bruno
Old 01-15-2004, 09:32 AM
mark10t
There is a relay in the ABS control box that has been known to 'stick' on occasion. Could be the culprit if the source of switched power on that circuit is 'hot'.
Just a thought....
-Mark
Old 01-16-2004, 10:35 AM
[BrUn]
My abs dash light come up again this morning, when I stopped the car I opened the hood and the abs motor and/or module (whatever) was still running. I have to remove the abs fuse to shut it off. I put back the fuse in place and the abs motor and/or module (whatever) remain shut.
Old 01-16-2004, 12:01 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Bruno,
Sometimes just a tap on the box (with your finger or the end of a screwdriver) will stop the ABS motor from running, until you can get a new relay. The relay is easy to replace. One screw in the middle of the ABS box, pop off the box top, replace the relay -- there are two, and I can't remember which is the culprit, at the moment. Mark can probably help you with that.
Randy Johnson
Mike Davis -- at Reading VI
