Old 02-07-2004, 02:37 AM
I don't see any article.
i also never hold my brake for more than a couple seconds unless im at a complete stop, and i try to reduce speed over distance while people barrel past me to a stop light.
yeah I do that.
Old 02-07-2004, 06:52 PM
LarryIII LarryIII is offline
The tires were rotated on my 92 this morning.
The nuts were tightened using an air wrench with a "torque stick." The torque sick was rated at 65 ft.-lbs.
I check the lug nut with my torque wrench when I got home.
They were right on the money.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 02-24-2004, 07:43 PM
mbtoloczko's Avatar
sans SVX
Originally posted by newsvx
Never had a problem at all! Track or autocross (back-to-back runs).
Harry
Which Axxis pads are you using?
Mychailo
Visit my locker
Old 02-25-2004, 05:26 AM
svxhunter svxhunter is offline
5 speeds rock! :D
Poor man's brake lines
Personally, I like the stock SVX brakes (with upgraded semi-metalic pads). I would like to go to the steel braided brake lines for a more firm feel to the petal, but that would move me out of the SCCA G-Stock class to modified.
You can improve the pedal without changing lines by adding a bunch of zip ties wrapped tight around the stock lines, perhaps every 1/2" or so.
Would this have an effect on your SCCA class?
Old 02-25-2004, 06:23 AM
Michael Blue's Avatar
Michael Blue Michael Blue is offline
Sold. :'-(
Re: Poor man's brake lines
That's got to be one of the funniest things I've ever heard, lol!
Not saying it wouldn't work, maybe it would, it's just hysterical!
Thanks!
'92 Pearl White LS-L Touring SOLD
4.44 Swap, trans cooler, trans filter, trans temp gauge
Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines
Raxles front axles
Old 02-25-2004, 06:39 AM
5 speeds rock! :D
I realize its pretty low class, but it reduces the flex in the lines! I wouldn't do it to a classy ride, but maybe it would beat the SCCA rules.
Old 02-25-2004, 08:44 AM
mbtoloczko's Avatar
sans SVX
I guess if you wanted to hide it, you could put some shrink wrap tubing over the zipties. :-)))
Mychailo
Visit my locker
