Old 12-29-2003, 08:53 AM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
OBD II Oxygen Sensor Code ??Which O2 Sensor is it??
The ONLY thing that has ever tripped my '96's check engine light is the following code/diagnosis from my EZ-Link diagnostic:
Freeze Codes
P0145 O2 Sensor Circuit Slow Response ( Bank 1 Sensor 3 )
Does anyone know for certain which of the 3 O2 sensors this is?
I COULD disconnect one at a time and run the diagnostic, but 20 degrees laying on my brick driveway isn't happening anytime soon!
Oh! The code pops up only once every 500~800 miles, usually at speeds above 60 and is the same code # everytime.
Thanks and HAPPY NEW YEAR!
Dave W.
______________________________
1996 Redd
Old 12-29-2003, 12:53 PM
Mr. Pockets's Avatar
Moderator
I can't tell you offhand what that code means, but I can offer some advice:
1. Simply disconnecting the sensors one at a time may not be sufficient. On pre-ODB-II SVXs, the ECU has to notice a problem on more than one occasion before it tells you something's wrong. ODB-II SVXs may be similar.
2. Even if you do disconnect the sensors, you don't have ot lie on your driveway to do it. I can't speak for the third sensor, but the connectors for the two O2 sensors in my car can be reached in the engine bay.
3. We have a tech Q&A forum for posts like these. I'm not complaining, just suggesting that you might get a better response to a technical problem in that forum.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 12-29-2003, 01:31 PM
wynndi's Avatar
Good points!
I have moved the post to the tech section.
Thanks!
Dave W.
1996 Redd
