Old 11-12-2003, 10:58 PM
Breck SVX
Carbon Intake Manifold...mmm
...all yours plus an engine for only $8,500
(though that was 3 years ago)
http://www.sdsefi.com/air34.htm
Out of curiosity, how much do you think it would cost to fabricate something like that?
I was trying to find that web page that has a pretty nice detailed section on svx engines for aircraft use but couldn't find it, does anyone know the link?
-Alex
Old 11-13-2003, 12:04 AM
Chicane Chicane is offline
Anti-BS Vigilante
Man, those headers look so shibby.
- Rob
Old 11-13-2003, 07:52 PM
svxsubaru1's Avatar
to bad he dident use the eg33 after the crash.
Old 11-14-2003, 09:05 AM
CigarJohnny's Avatar
Interesting. It seems there is, after all, a solution to the fuel management issues that have many saying that you will never be able to due too serious of a turbo mod to the EG33. Looks like the airplane folks have always known that which eludes many who want to turbo charge the SVX. Thing to find out is whether or not there is any reason it would not be adaptable to the SVX.
Another major change was to discard the stock EFI controller and replace it with a simpler and more suitable dual redundant, fully programmable EFI which had been specifically designed for aircraft use. I chose the FuelnFire - manufactured by Compass Avionics as I felt that it would give the flexibility, redundancy and the simplicity I was looking for. The only difficult part to this installation was the design and manufacture of a mounting arrangement for the dual cam position sensor PC board as well as a mounting plate for the trigger magnets.
Food for thought
Old 11-14-2003, 10:03 AM
Mr. Pockets's Avatar
Moderator
Food for thought
The author does very specifically say that the EFI controller he used was designed for aircraft use. That's not to say that it couldn't be adapted to street use, but I wouldn't bet on it being very easy.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 11-14-2003, 02:57 PM
Anti-BS Vigilante
Originally posted by Mr. Pockets
.... was designed for aircraft use.
I'm not sure if you guys know this, but anything aircraft related = $$$$$$$$$$$$$$$$$$$$$$$$
- Rob
Old 11-16-2003, 10:19 PM
drivemusicnow's Avatar
Poor College Racer
the only reason the cost of airplane engine internals is so high is because the difference between your fuel management when you're driving down the highway and your fuel management when you're flying 5000ft in the air is rather large, one, your engine shuts off and you start coasting... the other, you engine shuts off, and you die. (notice how he stated redundancy) basically though, it still means it can be done, and it can be done right... we just haven't found the right thing to do it with
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 11-16-2003, 11:23 PM
Anti-BS Vigilante
Uh, I wasn't referring to engine internals, nor was anyone else. It was about engine management electronics, and anything aviation related is EXTREMELY expensive, for the reasons you just mentioned.
- Rob
Old 11-17-2003, 10:03 AM
Porter
There are a whole host of engine management systems that will work on the SVX.
They include:
Electromotive TEC-II and TEC-III
Haltec
Motec
Microtec
Greddy E-manage
Dastek Unichip
Plus a great many more that are less well-known, like the
SDS shown in the link. Too bad it's quite slow compared to the more modern setups like the TEC.
My personal favorite for simple bolt-on tunability is the Unichip, though it's nowhere near as powerful as something like a TEC-III... you don't have to tune from scratch as with the standalone systems.
Old 11-17-2003, 11:49 AM
mbtoloczko's Avatar
sans SVX
They include:
Haltec
Motec
Microtec
Greddy E-manage
Dastek Unichip
Porter, in my research into stand-alone ecu's, I've noticed that several do not have the capability to fire 6 coils. I haven't researched the ones you mentioned yet. Do they all have the capability to fire 6 coils?
Mychailo
Visit my locker
Old 11-17-2003, 11:51 AM
Porter
The Unichip and E-Manage are actually piggybacks, but yes all of the above are 6-coil compatible in some fashion. There are several models of each available. Most of the above also support forced induction, anti-lag, launch control, and all kinds of other trickery like ECU controlled nitrous maps.
