Old 10-21-2003, 07:46 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Tell your boyfriend to rebuild the alternator. Alternator is dying and it may show up as good but trust us. It's not good.
If he takes it out and bring it back and say it's fine, dump him, come over to Chicago, I'll take the alternator and rebuild it and put it back in.
In the process, I can replace him too.
J/K and trying to cheer you up. Alternator can be tested and can come back as ok but when under load and moving in the car, some parts inside may not be touching or may be touching when they should not. Remember, it's a moving motor. Just rebuild it or replace it. If you were any closer, I'd let you swap alternators and see if that helps since my car is still OTR and I am in class.
Put it this way, you have repalced a batt. It has to be the alternator. While the car is running, check the voltage while driving. Get a volt meter and probe it at the cig lighter. When you press gas, it should be around 14.5 and when on idle, it will be around 12.5. Do that while you drive and also right as when all the lights comes on. You will see that your voltage dropped a decent amount.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 10-21-2003, 09:54 AM
StaceyVX
Subaru suggested that it is the regulator. Is the regulator inside the alternator? On some cars, it isn't. Also, if it's just the regulator, should I still have the whole thing rebuilt?
Old 10-21-2003, 11:22 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
It could also be a fuel pump and or mass air flow sensor....
Can you even get the car to start...?
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 10-21-2003, 12:42 PM
Seraph's Avatar
Take a big hammer and hit it and see if that fixes itself.
L
Current SVX: NONE
Old 10-21-2003, 12:48 PM
sounds lke the right tool
L
for the job, as long as your not working
on my car
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 10-21-2003, 02:12 PM
Seraph's Avatar
Re: sounds lke the right tool
on my car
I try. Yeah, you don't wanna hit it with a hammer.
Current SVX: NONE
Old 10-24-2003, 07:52 PM
The regulator is on the inside of the alternator and IIRC it must be soldered into place.
Old 10-25-2003, 02:32 PM
StaceyVX
So I had my boyfriend take it back to that place again and they took the alternator apart and replaced the regulator...Turns out they just "guessed" because they didn't see anything else wrong w/it and figured if it's an intermittent problem, that it has to be the regulator. He hasn't put it back in my car yet, but fingers crossed!!! I don't wanna have to shell out more money for guesswork.
Old 10-25-2003, 06:20 PM
Mine was bad...a couple times now.
Both times the alternator bench tested fine. Both times the regulator fixed it.
Old 10-27-2003, 11:11 AM
StaceyVX
It cost $70 to put in a new regulator. He hasn't gotten to put it back in unfortunately because on Saturday he was hit by a car while riding his motorcycle. I'll keep you guys updated on the car issue. Thanks!
Old 10-27-2003, 07:08 PM
Shot king
Ouch, hope he feels better.
Old 10-28-2003, 05:52 AM
6evil9
just outa curiosity why u all so sure about alternator?
ok if u have not dead battery ur car WILL RUN PERFECTLY WITHOUT ALTERNATOR!!
had it with mine, my steering belt sliped out and ripped, so i had to drive without alternator and steering, and it drove and worked all good.
so by my understanding the problem, the bad alternator can cause only the battery going flat. Had it with mums bluebird- alternator dead, light on, battery flat in couple of hours of driving.
Starter dying- car starts every second time, then just dies, smash with hammer and its ok for a while.
to the post about MAF. car will go alright without MAF. tried that too...
So problem like car dies while it runs and it wont start is something else.
(when steering belt rips, all lights come on)
so maybe u should think wider?......
Old 10-28-2003, 06:04 AM
6evil9
In addition, advises here are free, checks u run are free, replacing parts by guess... hmm not priceless but expensive
so advise, make sure first then replace...
i got rough iddle for 2 months, and still dunno what it is, but replacing half engine just by guessing (sparks, coils, TPS, fuel pump, fuel pressure regulator, all vacuum hoses, PCV, temp sensor, injectors and so on...) well thats expensive! but checked half of that and turned to be ok...
Old 11-05-2003, 06:41 PM
StaceyVX
New regulator...Drove the SVX for about 10 minutes and it died again. Got it to start and died again. Still starts, but eventually dies. I'm at a loss.
Old 11-05-2003, 07:53 PM
nextcubepro
I had a car with an alternator that ran for 30 minutes as long as I sprayed water into the alt and didnt shut the car off.
A car will run with a dead alt but not a dead battery.
Unplug your mass airflow sensor and drive the car for a while. You will get about 5 MPG, but see if your car keeps dying.
