HELP! Catalytic Converter falling apart
Help Me! My car makes a grinding sound when I accellerate and the shop tells me my catalytic converter is falling apart! I have spent tons on repairs lately and can't afford any more. Can I fix this problem myself? How? How much would a new or used one caost and could I install it myself? Please comment.
Early deceased SVXWN Member July 1986 -- February 2007 Michael - Duct Tape Man 1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit 1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something. "It's only after we've lost everything that we're free to do anything" - Fight Club "This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X |
does it sound like metal grinding cause that might be your resonator. and that you would need to take out. but that should be a lot cheaper.
hope that helps |
If it's just a piece of metal coming off the CAT or Resonator you may be able to fix it with some wire. Stainless steel wire is best.
What you say does not make a lot of sense to me. The exhaust system runs on the bottom of the car. Above the exhaust pipe, and rear CAT and resonator is a HEAT SHIELD. Above the heat shield is the drive shaft. In all likelyhood it is the heat shield that's hitting the drive shaft. The heat shield is very flexable and can be bent. The drive shaft bearing may also be coming loose. This could be similar to the problem I had. Check out this thread.
Thanks. I'll check the heat sheild. The place that rebuilt my trannie were the ones that said the cat was falling apart. Upon further examination, the sound might be coming from farther back than the cat. Also, it only makes the noise at 1500 rpm and 3-4000.
I had the exact experience svx_commuter described in his forum; turned out to be trannie fluid leaking into front diff. Old trannie had to be rebuilt. Once again thanks and I'll check fro rubbing heat sheilds. I will write back if i can't find anything. |
Location of Origination Discovered
OK, I put my car up on ramps and found out wherre the sound is coming from. It's Between the Catalytic converter and the Muffler in something that looks like a Cat but smaller. On this attatched Chilton's picture it's part number 33.
Anyone know what this is or what it's for? Do you think I could just cut it out and put in a piece of pipe instead?
OK, I put my car up on ramps and found out wherre the sound is coming from. Not any driveshaft, it makes the sound in neutral but not as loud.
It's in a thing Between the Catalytic converter and the Muffler in something that looks like a Cat but smaller. On this attatched Chilton's picture it's part number 33. Anyone know what this is or what it's for? Do you think I could just cut it out and put in a piece of pipe instead?
yeah, from what it looks like it the resenator, i cut mine out and put a straight pipe instead. doesnt change the sound that much at all, maybe a tiny bit louder, but hardly noticable.
hope it helps jerad |
Isn't the resomator up front?
This is either a secondary cat or muffler. It's getting louder though. Anyone else have this problem? |
part 33:
that is the resenator, it sits between the muffler and the last cat. |
I also had this exact same problem. However you have already had the proper advice laid before you. Have a nice muffler shop cut out the resonator and just throw in a straight pipe. I've seen it posted a few times before, so it seems to be a popular fix. And it works very well.
exhaust
I recently had my exhaust expert put in a straight 4" diam. muffler in place of the original resonator. Car is whisper quiet(unless you get on it). This repair cost me $60. BTW I have a brand new cat. with the hardware. I paid $350 for it , if any body wants it make me a reasonable offer and I'll ship asap (Afetr payment of course)
"oh blessed mother of acceleration don't fail me now!"-Dan Ackroyd: BLUES BROTHERS '92 Teal LS-L Sold to North Carolinaians! 1972+'73 BMW 2002 tii('72) someday I'll finish restoring them,...someday (for sale) |
Thread Tools | |
Display Modes | |
