Old 09-11-2003, 04:57 PM
AFBeefcake's Avatar
Subaru Swapper
how hight should a SVX be off the ground
I think my strut springs are weak in the rear.
can some one tell me how hight the car should be in the front and in the rear.
on my car the top of the rear tire is just up inside the rear fender
2005 Legacy GT
My WRX's Cardomain Page
Old 09-11-2003, 05:02 PM
deruvian
I'm not so sure about the front and back individually, but I believe that the lowest point on the front bumper cover should have 5.6 inches of ground clearance (about 5 and 9/16 inches).
Old 09-11-2003, 05:04 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I actually asked mike this. Mine looks lower in the back than the rear but its because the rear wheelwell is flat on the top so it gives the illusion that its lower. Hope thats your case.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 09-11-2003, 06:13 PM
mbtoloczko's Avatar
sans SVX
Sagging rear ends seem to be a common issue with SVXes. Could be the springs sagging, but it could also be something with the strut mount. The rubber cushion could be collapsing, or the upper spring seat could also be collapsing.
Mychailo
Visit my locker
Old 09-11-2003, 06:23 PM
Boone
Here's a .pdf with the spec.
Old 09-12-2003, 01:46 PM
mbtoloczko's Avatar
sans SVX
Wow. Nice tidbit of info. Is that in one of the service manuals?
Mychailo
Visit my locker
Old 09-12-2003, 06:48 PM
Subafreak's Avatar
Superbeast
Um, how much does your stereo stuff weigh? That may add a little sagg.
Old 09-12-2003, 10:41 PM
Boone
It's from the SVX CD sold on ebay, at least it seems official.....
Old 09-13-2003, 06:46 AM
AFBeefcake's Avatar
Subaru Swapper
well I don't know, but I what guess about 150-200 pounds.
I used 2/3 a sheet of 3/4 MDF to make the box.
2005 Legacy GT
Old 09-13-2003, 07:49 PM
Wheel Arch Height.
From the official Japanese RHD manual : -
Measurements from center and highest point under edge of wheel arch to the the center of the wheel hub.
Front. 380 m.m. +10 , -20, or 14.96 inches + 0.39, - 0.79
Rear. 335 m.m. + 10, - 20, or 13.19 inches + 0.39, - 0.79
Old 09-15-2003, 02:03 PM
mbtoloczko's Avatar
sans SVX
If you've got 150 lbs centered over the back wheels, the car will sit about 0.75" lower in the rear. If its centered further behind the back wheels, then you can expect it to sit even lower in the rear.
Mychailo
Visit my locker
Old 09-15-2003, 02:28 PM
AFBeefcake's Avatar
Subaru Swapper
I guess I should just lower the front. going to need coil overs so I can set the back a little higher and the front a little lower.
ground controls and konis hopfuly next summer
2005 Legacy GT
Old 09-16-2003, 08:36 AM
GreenMarine's Avatar
From POST-***** to LURKER
That's what I'm waiting on!!! I'd like to make the car sit even or possibly a little lower in the front than in the rear but not noticably... Just want it to look perfectly level... Mine looks like it is riding on the rear bumper after doing the 5 speed conversion... We took nearly 160lbs off the front wheels with the conversion so I need that suspension to kinda level things out a bit...
Old 09-22-2003, 06:37 PM
svx_commuter's Avatar
Re: how hight should a SVX be off the ground
Oh your rear strut mount may look like this.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 09-22-2003, 08:11 PM
AFBeefcake's Avatar
Subaru Swapper
no mine are not rusted like that. I checked them.
the left rear one was but I replaced it with a used one.
2005 Legacy GT
