Old 09-10-2003, 09:27 PM
gcookaustin
Question 1-2 shift causes clunk
My 1-2 shift has always been rather crisp, but lately it's been making a sort of clunking noise. Is this a transmission mount, or could there be something else? The shift seems slightly less smooth than before, so I don't know what the deal is. I haven't messed with the resistor. I've searched through other posts but haven't found anything relative.
Old 09-11-2003, 12:14 AM
deruvian
me too
My car appears to be doing something similar to that too. It was fine for a while, but it's been doing it a lot lately. Mostly when the engine is warmed up.
When accelerating from a stop (or very low mph), it typically shifts from 1st to 2nd around 2k rpm. When it shifts, there is kind of a "clunk, clunk", and then 2nd fully engages. I can both hear and feel the "clunking." However, if I let off the gas a little right before it shifts, then it doesn't appear to happen. Or, if I hard-accelerate, then the shifting is much firmer (and around 3.5k rpm), and it doesn't appear to happen here either.
I have no idea why it's happening, and also have little knowledge of the symptoms of tranny problems. One of my car-modding friends said that I may have a vacuum-line problem, and the troublesome shifting may be a result of it.
Any ideas for gcook or myself?
- Garrett (whoa, you too? rad!)
Old 09-16-2003, 03:29 PM
rbalach rbalach is offline
Mine used to do that too, shop said its the tranny mount. Had it replaced, everything has been fine since then.
I didn't notice anything in the way it was shifting though. But i'd first check the tranny mount. Not very expensive to fix.
RB
Old 09-16-2003, 04:01 PM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Could be your resistor too, that is how mine started.
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
