Old 09-05-2003, 04:20 PM
imjeremy77
Unhappy Crankshaft pully
Symptoms: squealing belt, then burning rubber smell, then alternator belt fell off resulting in no power steering.
Dealer says it's my crankshft pully, $230 just for the part!
Is it easy replace this thing myself?
Old 09-06-2003, 12:29 AM
If you are somewhat mechanically inclined or have patience and a scan of the shop manual its no problem at all. You will have to pull the belt off which means compressing the timing belt tensioner and then setting the timing marks and pulling the pin but other than that its about an 10 min. job....
Old 09-06-2003, 01:03 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Re: Crankshaft pully
You do have a choice, you can install an aftermarket
underdrive crank pulley in place of stock.
It adds some gains in hp and torque on top of it
all.
We have them on special if you, if you get a chance
check out our store link below and email me for pricing.
Theres lots of good info here if you do a search for
installation, Want A Fast input is pretty direct and
helpful.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 09-06-2003, 12:18 PM
alacrity024
i agree with dayle-
an aftermarket underdrive pulley will cost you less, and since it's made from one piece of aluminum, it won't separate like your stock one did. the only issue is that you'll need to run different length alternator and a/c belts than OEM calls for, but dayle can hook you up with the proper belts as well.
as for it being a do-it-yourself job, it absolutely is.. there's a few methods of holding the crank pulley still while you reef on the nut (i think it's a 22mm) holding it to the engine. since the pulley is separated, it'll prove fruitless to use a strap wrench to hold it still (the inside will spin freely and the outside will stay still).. some people will advocate bracing a breaker bar against the engine and keying the starter to break the bolt loose, but i think it's sketchy as hell..
ask around, someone will be able to give you a pretty thorough step-by-step
-adam
Old 09-06-2003, 12:53 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Re: Re: Crankshaft pully
all.
helpful.
are they actually under driven(smaller circumference) or are they merely lightened? The perrin pulley is lightened but same diameter
phil
~Phil
Old 09-06-2003, 05:31 PM
imjeremy77
Thanks!
Thanks for all your replies. Because of time constraints I've decided to have the dealer do the work. (Hopefully it won't break my bank too bad) They're supposed to give me a final estimate Monday sometime. Can this breaking of the crankshfat pully cause any other damage? (ie timing belt, etc)
Old 09-07-2003, 12:40 AM
alacrity024
well, if the crank pulley separated violently (read: exploded) it would've gone bouncing around the engine bay.. probably the most damage it could easily do is to wear a circular impression of itself onto your timing belt cover. it might have dug deep enough to necessitate a new cover, but probably not..
-adam
Old 09-07-2003, 12:06 PM
Subafreak's Avatar
Superbeast
Ouch! $230 just for the part + what ever the dealer is going to gouge you for labor. (thank full I can work on my own car). I think the under drives go for like $100 to $150? and it really is easy to do it yourself.
BTW. Want a fast, what are you talking about?, you don't have to touch the timming belt to swap a crank pully.
Old 05-31-2004, 11:32 AM
Loki
Unhappy
So I posted like 2 weeks ago about belt problems, I just now got a chance to look at them as Ive been driving my Celica. I tried loosening the belt tensioner (down and to the passanger side of the alternator) and it worked fine, but once I actually got the belt on and tried to re-tighten the tensioner it snapped... so that really sucks, does anyone know of anything that I can do? I dont really know how to get the broken portion of it out. Once I get it out and replace the bolt Im sure that the car will be fine (I hope, with force (pulling hard on the belt) the cam pulley moves almost 1/4 inch). Does anyone have experence/know what to do with this?
Thanks in Advance.
Old 05-31-2004, 01:13 PM
just now saw that...my bad I was thinking about the cam pulley...I apologize for the ignorance...
Old 05-31-2004, 01:39 PM
double ouch! my lightwieght slightly underdriven pulley was like $80 (when OVIDIUStan was selling them), and the belt was $10-15.
the 'Subafreak Engine / Crankshaft Nut Cracking Method' is not sketchy at at - you only need to 'touch' the key in the ignition for an instant, and it comes loose! thanks again, Mr. Freak!
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 06-01-2004, 03:55 PM
Loki
Sorry to bump this, but I could really use some input on the broken bolt.
Thanks in Advance
Todd Gilbert
Old 06-01-2004, 07:04 PM
immortal_suby's Avatar
Thread Killah
An EZ-out should work - can you post a picture of the broken bolt?
Locker Link
2015 BRZ Limited 6MT
