Old 11-12-2004, 01:06 PM
cbx-man cbx-man is offline
To me it sounds like some plugged injectors. I had the same symptoms once. I fixed it for less than $3.00 What did I do, you ask? Marvel Mystery Oil. Use it @ the rate on the bottle (in the fuel tank) and you should see results in half of a tank! It is THE BEST fuel system cleaner I have ever used!
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 11-15-2004, 01:28 PM
alia176 alia176 is offline
I vote for the IAC. This is a common issue in many vehicles with higher mileage. Can't wait to figure out what it is!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 03-25-2005, 09:24 AM
any luck with this helping your stalling out???
Old 02-25-2008, 08:23 PM
gschabel gschabel is offline
Thumbs up Warmed Up Stalling Corrected!
After my 97 LSI warmed up, it ran fine, but at idle it was a bit rough, nothing terrible, but when you put it in park, the idle was hunting all over the place then finally stalling 100% of the time. If you kept it in gear, it did not stall, but hunted a bit. No codes thrown either.
Well, much discussion about the MAF, so I took it out and cleaned it good with some Brake Parts Cleaner (Carb Cleaner would probably work as well) reinstalled, went for a ride, and problem still existed! Damn!
Frustrated, as it now began to snow a bit, I took apart/off all the intake hoses and did a thorough cleaning of the throttle intake body and butterfly valves with Carb cleaner (both ports).
With everything apart the car does not run, so I put it all back together and after a few tries and flooring it, it finally started, and blew out black junk out the exhaust.
Time for a ride, and guess what, a perfect idle and no more stalling!! Two days later, we're back to good as new!
A can of carb cleaner can be your friend for this problem!
Good luck!!!
Old 02-25-2008, 09:03 PM
The preceding post by gschabel, together with the above, shows what happens if solvent can be persuaded to enter the IAC and free up the internal rotary solenoid valve.
