Old 08-18-2003, 02:43 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
Why God WHY!!!!???
my car is dead
there is a loud thunking noise that is coming from the transmission
it got faster as the car increased and only when the gas is on, but it was independant of engine rpm's,
the car is currently broken down on the side of the road about 10 min from my house, and about 10 min from kerven subaru...
anyone have any ideas what this might be?
the car still accelerates, but i was afraid to after stopping at a sign it was really bad, and i pulled off the side of the road...
i can fell the clunking
SV What?
Old 08-18-2003, 05:21 AM
Sounds like the front diff ....the bright side, it's cheaper than a tranny rebuild
Old 08-18-2003, 07:47 AM
Green1995SVX
I agree. Sounds like the front diff. I would imagine the added pressure on the front diff in combination with the loss of fluid a couple months ago made it break.
Mike
Old 08-18-2003, 08:43 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Oh I hate that noise. I had 3 teeth knocked off of my ring gear in the front diff. I feel for ya man.
Quick, somebody buy his OBS!
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 08-18-2003, 09:40 AM
NomadTW's Avatar
can i drive the car w/o the teeth w/o risking further damage to anythikgn else/ other gears in the difff
if only one of the gears has teeth knocked off of it...
can i just replace that gear, or does the entire thign need replaced
SV What?
Old 08-18-2003, 12:14 PM
NomadTW's Avatar
how much did it cost u to fix it elnino?
i plan to do the work myself tho... and hopefully get the diff from the parts car..
SV What?
Old 08-18-2003, 01:10 PM
You'll have to pull the tranny to swap the front diff's....so it'd be a good time to swap in a Legacy 4.11 front and rear diff ...or better yet, go ahead with the 5 speed swap
Old 08-18-2003, 04:59 PM
lee lee is offline
DON'T drive it. As the teeth go round and fail to mesh, they load the case and it's aluminum. I had to buy another case which at the time meant buy a whole transaxle from a salvage yard. If your's is only making noise under throttle, you may have stopped in time to just need gear replacement.
Old 08-19-2003, 01:03 AM
NomadTW's Avatar
oh no, it's dead
completely dead
i can feel when the missing tooth/teeth try to mesh it's horrible
the 5 speed swap would be nice but i don't have the 1000 bux that it's gonna cost me to do it yet
i don't even have the money to find a salvage yard transmission
altho putting in the 4.11's in the svx w/ the auto would be nice,
i figure while i'm in there w/ the tranny pulled i'll try to fix the solenoid 3 (which is what i hope is why my awd is broken)
SV What?
Old 08-19-2003, 07:54 AM
GreenMarine's Avatar
From POST-***** to LURKER
Do 4.11's in the Auto!!!! I bet that would just launch off the line.... Probably be even faster than a 5 Speed!!!! Porter's feels like it pulls harder than mine!!! He just has a regular tranny though... But he does have a suspension and That does make a BIG diffrence in braking feel... Could go both ways...
Old 08-19-2003, 11:34 AM
NomadTW's Avatar
the 4.11's wouldn't make nearly the difference that the whole 5mt would make... the gearing is still super tall even w/o the 4.11's isn't it?
SV What?
Old 08-19-2003, 12:58 PM
elninoalex's Avatar
Registered Abuser
I couldn't have said it better myself. If you have any future aspirations of doing a 5 spd swap, now is the time. If you want to fix the front diff, then you need to replace the ring and pinion, which I think are around $500 new. Probably ate up the pinion bearings to, which are almost $200 for the pair. Requires disassembly of the diff case and rear extension because the pinion goes all the way through the tranny. If your tranny is suspect to begin with, it doesn't like a wise move to fix it. Finding used front diffs is very difficult. 5spd 5spd 5spd.
Stephen
PS. When I fixed mine, I got a Subaru reman with Level 10 valvebody for $3500.
Old 08-19-2003, 06:48 PM
Porter
Bah, so do the 4.444 front and rear diff out of a 2000+ Impreza RS automatic. Should bolt right up. I dunno if the rear axles will fit, seems like they would but you'll have to talk to someone who's done an LSD to LSD swap.
Old 08-19-2003, 09:40 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
you know i gave randy my old diff awhile back, email ardub and see if he has it still or if he ended up using it.
phil
~Phil
Old 08-19-2003, 10:54 PM
NomadTW's Avatar
oh i already have the used diff
mike's parts car will be donating that
the rest of the tranny is not suspect in the slightest
no slipping at all, tranny is in excelent condition
i'll start looking around the junkyards for some 4.11's
what cars have the 4.11's?
SV What?
