Old 04-30-2003, 03:22 PM
mbtoloczko's Avatar
sans SVX
barely beat a 240SX...
I thought I was going to dust the guy, but I only managed about 2 car lengths by the time I hit 80. After that though, he couldn't hang. I definitely need more power and a 5 speed tranny. :-)
Mychailo
Visit my locker
Old 04-30-2003, 04:06 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
I absoultely destroyed my friends I/H/E 240 with the 5spd, got him out of the hole and pulled in third
phil
~Phil
Old 05-01-2003, 06:53 AM
SubaSteevo's Avatar
No longer blue member
240's are pretty quick
I almost bought one before I got the SVX. It only has about 160hp but also only weighs about 2400. The one I looked at was kinda sketchy though so I passed (speedo didn't work, had been repainted, wrinkles on the hood, front dash/console wasn't attached very well). The odometer said 71k but the interior looked to have much more wear so I'm guessing it was in an accident and the dash was replaced (with one that had only 71k) and they forgot to reconnect the speedo.
P.S. There's also a couple of different trim lines with different specs
-Steve
01' MSM Lexus IS300
Old 05-01-2003, 07:18 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
i raced a 240 once.. looks completly stock . well it wasnt it was this guy named jay here. has the sr20det swap pushing like 500 hp . after that well u do the math =>
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 05-01-2003, 08:47 AM
Phast SVX's Avatar
Re: 240's are pretty quick
all have KA24DE engines, rated at 160 hp
You can swap an SR20DET in as solar stated can make big power (much like the 4G63) with a fairly small pocket. I see more and more of them all the time.
~Phil
