If the POWER light blinks 16 times upon startup...
...and shifts are scarilly buttery smooth and very slippery...what does it mean? (not my lil claret bueaty thank goodness =-)
Thanks in advance. |
Tranny problem
The owner's handbook says if this light blinks "for 8 seconds or more" after ignition ON, there may be a problem with the transmission control circuits. See your dealer.
There will probably be a code saying what the problem is. Do a search on code reading, you will be able to find out what the TCU thinks is wrong. Best of luck. Joe
Power blinks
Yeah, your getting a code. Do a search of the sight and follow the posted directions to answer the code. It will then tell you what's wrong.
Procedure is in the "How To" personal locker. Click "personal lockers" at the top of the page, then, scroll down to the How To locker.
I had 1 long flash followed by 16 quick flashes. And my rear wheel drive wasn't working. Try accelerating hard on wet pavement, around a corner, from a dead stop. If you spin the inside front really bad, then there is a solenoid burned out, which is replaceable. That's all I Know.
cbx-man '92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter '92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft '80 Honda CBX in-line 24 valve 6 cylinder |
No i didnt pull the code yet but i will tomorrow...and the RWD isn't working...and the shifting is definitely screwed up...and it wont hold 4th gear...
