4 wheel steer geometry (JDM)
I'm having a few "issues" with my 92 JDM Alcyone, I will shortly be changing the front track rod ends, I will be getting the tracking checked on a 4 wheel tracking/alignment machine, does anybody know what the rear settings are? are they likely to be the same as a normal SVX that does not have rear wheel steering?
Thanks Mal |
Re: 4 wheel steer geometry (JDM)
Check with Shane Hobson here in NZ
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
I don't know the answer to your question, but I may be able to dig out a wheel alignment result for my car if that helps. But I don't have any factory specifications.
Thanks! that would be a start.
Thread Tools | |
Display Modes | |
