Old 01-11-2013, 02:27 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Wipers
I need a new set of wipers but I know for sure that the ones I have on just aren't the right ones. I looked in the owner's manual and it says nothing about the type/lenght of the wipers.
Can anyone pitch in?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 01-11-2013, 05:52 AM
Re: Wipers
22" for the driver and 19" for the passenger side is ringing a bell, but I'm not totally certain. A parts store should be able to look it up for you though.
Old 01-11-2013, 05:59 AM
Re: Wipers
22" and 20", I bought a set yesterday at Advance Auto when I was in the USA.
Old 01-11-2013, 08:11 AM
dbarnblatt's Avatar
Re: Wipers
Correct:
Driver - 22"
Passenger - 20"
Rear - 18"
Old 01-11-2013, 08:26 AM
jetboy's Avatar
Re: Wipers
Ah, that's very nice info, thanks
Are ALL wipers of the same angle etc. It's a global standard, I can't go wrong as long as the inches are right?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 01-11-2013, 09:06 AM
theflystyle's Avatar
Re: Wipers
I would also recommend a set of PIAA if you care
1994 SVX LSi
2008 Legacy 3.0R
Old 01-11-2013, 09:22 AM
Re: Wipers
I also use 19" wipers in the rear instead of 18". Only extends 1/2" more on each side of the arm and increases the wiping area.
Old 01-11-2013, 09:30 AM
dcarrb dcarrb is offline
Re: Wipers
In the U.S. any "universal" refill would do and I imagine it's the same anywhere. I like ANCO blades. You'll have to decide whether to replace just the blade, or the entire assembly. I prefer the latter.
dcb
Old 01-11-2013, 12:20 PM
SVX_MY_BABY's Avatar
Re: Wipers
I still use the OEM assembly with the bumpers on them (which are still available from Subaru). The narrow universal inserts work well. Last time I ordered blades from Subaru they only lasted a couple of months. Ithink they were so old they had rotted.
Peter
Old 01-11-2013, 01:03 PM
Re: Wipers
I did something similar last time I changed the front ones. The 20" one I was replacing was in better shape than the 18" one on the back, so I swapped it over. Actually increased the area that gets wiped by a good amount, especially the top section of the window. 19" would fit a bit better I think.
Old 01-12-2013, 06:25 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Re: Wipers
Info form piaa website.
SVX92-97
D.S.C1/C1 22" 550mm
P.S. C1/C11 20" 500mm
REAR C1 18" 450mm
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
