Old 09-06-2012, 09:44 AM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
Removing a stripped(?) bolt
Need a bit of advice on how to get a couple stuck bolts out. I'm assuming they are stripped or somehow messed up either on the bolt threads or the threads they go into but not sure, this is a new one for me.
A couple of the bolts under the front of the car that hold the big plastic under cover on. The cover has long since fell off when the holes tore bigger than the bolt heads over time. But the bolts are still in place and just spin freely in there. I've tried putting extreme downward pressure on them with vise grips while at the same time trying to unscrew them with a ratchet, but again, they still just turn in place forever. They seem to be stuck in place, free to sping, but neither able to tighten or loosen beyond the point they are at.
And now even more exciting, one of the bolts that holds my driver's seat in has done the same thing so I can't remove my seat either!
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 09-06-2012, 10:45 AM
Re: Removing a stripped(?) bolt
Grind/cut off the head of the bolt and push what's left through the hole. If you have access, you can just put a nut on the backside and hold it as you tighten down the bolt. Or otherwise, more proper would be to weld the nut where the existing one was. They are usually just held in by a 2 tach welds on opposite sides and often times break away.
Old 09-06-2012, 03:10 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Hold the head of the bolt with a vise grip while using a sawzall to cut it off at the threads.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 09-06-2012, 03:53 PM
davew833 davew833 is offline
I'm in the same predicament with one of my seat bolts. I couldn't figure out any way to access it since it seems to be down inside the frame. I ended up drilling some holes and putting some machine screws into the seat frame & floor to keep the seat from rocking, but I have no idea how I'll ever get the seat out if I need to.
davew833@yahoo.com
Former 6-time SVX owner
