need help on removal/installation of main power window switch
How do I remove and install the main power window switch on driver's door?
Re: need help on removal/installation of main power window switch
Remove the 2 screws near the hinge on the door, then the 2 inside the door slot, and the 1 underneath a plastic cover under the handle. After that unplug 2 wires and unscrew the unit from the door card.
Once you've removed the aforementioned screws, pull the door panel outward from the bottom to unsnap the fasteners, then lift straight up. Hardest part of the job is getting the door lock button aligned for re-installation. Use a magnetic screwdriver to hold the smallish screw that's beneath the plastic cover underneath the door handle.
dcb |
be care ful not to disassemble the door lock switch because, there is alot of small parts that make it work.\ i had mine apart and i was lucky to get it together
