remove the throttle body
There m ust be a "how too" to remove the throttle body. I have the PCV valve off & cleaned, can't get it started back on sooooooooooooo, I'm going after some room by removing the throttle body. I know I have seen the step by step before, can't find it.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
Re: remove the throttle body
Removed the throttle body & was able to reinstall the PCV valve, what a PITA!!!
If I only do this every 12 years, OK....... All my idle issues went away. The throttle body was in need of cleaning, that's next. There were no signs of cracked or brittle vac hoses, life is good, especially an hour into happy hour
One note: You didn't replace the throttle body gasket, so if you notice vacuum leak symptoms in the future, that would probably be a likely culprit.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 06-13-2012 at 06:51 PM. |
